add parameter to all childrent part and all Sub-Assembly code
tamnn.designer
tamnn.designer
Hi Sir,
i am doing the stupid way. I used 2 code.
1st. Add all parameter from external rule into the main assembly and Sub-Assembly
2nd: I copied all parameter from the current main assembly into all children part.
So that lead to Parameter from Assemblies = Parts. That is not good for me later. I would choose which parameter will add into Assemblies, and which parameters will go all children parts.
Finally: One code combination 2 code by only 1 code but choose the 2 destination
- I would want all parameter in this code input to all parts.
- Only 3 pars Xcubic, Ycubic and Zcubic input to main assembly and sub-assembly only "
Thank a lot and best regards
JelteDeJong
You can try this:
Sub Main()
    If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then Exit Sub
    Dim doc As AssemblyDocument = ThisDoc.FactoryDocument
    Dim paramsData As New List(Of List(Of Object))
    paramsData.Add(New List(Of Object) From {"extent_dim_X", "1", UnitsTypeEnum.kMillimeterLengthUnits})
    paramsData.Add(New List(Of Object) From {"extent_dim_Y", "1", UnitsTypeEnum.kMillimeterLengthUnits})
    paramsData.Add(New List(Of Object) From {"extent_dim_T", "1", UnitsTypeEnum.kMillimeterLengthUnits})
    paramsData.Add(New List(Of Object) From {"part_area", "1", UnitsTypeEnum.kMillimeterLengthUnits})
    paramsData.Add(New List(Of Object) From {"bend_number", "1", UnitsTypeEnum.kUnitlessUnits})
    paramsData.Add(New List(Of Object) From {"Xcubic", "1", UnitsTypeEnum.kMillimeterLengthUnits})
    paramsData.Add(New List(Of Object) From {"Ycubic", "1", UnitsTypeEnum.kMillimeterLengthUnits})
    paramsData.Add(New List(Of Object) From {"Zcubic", "1", UnitsTypeEnum.kMillimeterLengthUnits})
    paramsData.Add(New List(Of Object) From {"thread_hole_number", "1", UnitsTypeEnum.kUnitlessUnits})
    EnsureParamsExist(doc, paramsData)
    Dim allSubAsms As List(Of Document) = doc.AllReferencedDocuments.Cast(Of Inventor.Document).Where(Function(d) d.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject).ToList
    If allSubAsms Is Nothing OrElse allSubAsms.Count = 0 Then Exit Sub
    For Each oSubAsm In allSubAsms
        EnsureParamsExist(oSubAsm, paramsData)
    Next
    Dim allSubParts As List(Of Document) = doc.AllReferencedDocuments.Cast(Of Inventor.Document).Where(Function(d) d.DocumentType = DocumentTypeEnum.kPartDocumentObject).ToList
    If allSubParts Is Nothing OrElse allSubAsms.Count = 0 Then Exit Sub
    For Each part In allSubParts
        Try
            CopyUserParameters(doc, part)
        Catch ex As Exception
            MsgBox("Problems while making parameter copies to part: " & part.DisplayName)
        End Try
    Next
    If doc.RequiresUpdate Then doc.Update2(True)
End Sub
Public Sub CopyUserParameters(sourceDoc As AssemblyDocument, targetDoc As PartDocument)
    Dim sourceParameters As UserParameters = sourceDoc.ComponentDefinition.Parameters.UserParameters
    Dim targetParameters As UserParameters = targetDoc.ComponentDefinition.Parameters.UserParameters
    Dim targetParametersList As List(Of UserParameter) = targetDoc.ComponentDefinition.Parameters.UserParameters.Cast(Of UserParameter).ToList()
    For Each source As UserParameter In sourceParameters
        If (targetParametersList.Contains(source)) Then
            Dim newParameter = targetParameters.Item(source.Name)
            newParameter.Expression = source.Expression
            newParameter.ExposedAsProperty = True
        Else
            Dim newParameter = targetParameters.AddByExpression(source.Name, source.Expression, source.Units)
            ' iLogicVb.UpdateWhenDone = True
    Next
End Sub
Sub EnsureParamsExist(oDoc As Document, oParamsData As List(Of List(Of Object)))
    If oDoc Is Nothing Or (oParamsData Is Nothing OrElse oParamsData.Count = 0) Then Exit Sub
    If oDoc.IsModifiable = False Then Exit Sub
    Dim oUParams As UserParameters = oDoc.ComponentDefinition.Parameters.UserParameters
    For Each MainEntry In oParamsData
        If MainEntry.Count = 0 Then Continue For
        Dim oUParam As UserParameter = Nothing
        Try
            oUParam = oUParams.Item(MainEntry.First)
        Catch
            oUParam = oUParams.AddByExpression(MainEntry.First, MainEntry.Item(1), MainEntry.Last)
        End Try
        Try
            If Not oUParam.ExposedAsProperty Then oUParam.ExposedAsProperty = True
            Dim oCPF As CustomPropertyFormat = oUParam.CustomPropertyFormat
            oCPF.Units = oDoc.UnitsOfMeasure.GetStringFromType(MainEntry.Last)
            oCPF.Precision = CustomPropertyPrecisionEnum.kThreeDecimalPlacesPrecision
            oCPF.ShowLeadingZeros = True
            oCPF.ShowTrailingZeros = True
        Catch
        End Try
    Next
End Sub
Jelte de Jong
Blog: hjalte.nl - github.com
tamnn.designer
Thank you very much for your support.
It's worked with No. 1 as bellow. No 2. I just want to copy only 3 parameters NOT all parameter.
1.  I would want all parameter in this code input to all parts.
2.  Only 3 pars Xcubic, Ycubic and Zcubic input to main assembly and sub-assembly only "
