You can try this:
Sub Main()
If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then Exit Sub
Dim doc As AssemblyDocument = ThisDoc.FactoryDocument
Dim paramsData As New List(Of List(Of Object))
paramsData.Add(New List(Of Object) From {"extent_dim_X", "1", UnitsTypeEnum.kMillimeterLengthUnits})
paramsData.Add(New List(Of Object) From {"extent_dim_Y", "1", UnitsTypeEnum.kMillimeterLengthUnits})
paramsData.Add(New List(Of Object) From {"extent_dim_T", "1", UnitsTypeEnum.kMillimeterLengthUnits})
paramsData.Add(New List(Of Object) From {"part_area", "1", UnitsTypeEnum.kMillimeterLengthUnits})
paramsData.Add(New List(Of Object) From {"bend_number", "1", UnitsTypeEnum.kUnitlessUnits})
paramsData.Add(New List(Of Object) From {"Xcubic", "1", UnitsTypeEnum.kMillimeterLengthUnits})
paramsData.Add(New List(Of Object) From {"Ycubic", "1", UnitsTypeEnum.kMillimeterLengthUnits})
paramsData.Add(New List(Of Object) From {"Zcubic", "1", UnitsTypeEnum.kMillimeterLengthUnits})
paramsData.Add(New List(Of Object) From {"thread_hole_number", "1", UnitsTypeEnum.kUnitlessUnits})
EnsureParamsExist(doc, paramsData)
Dim allSubAsms As List(Of Document) = doc.AllReferencedDocuments.Cast(Of Inventor.Document).Where(Function(d) d.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject).ToList
If allSubAsms Is Nothing OrElse allSubAsms.Count = 0 Then Exit Sub
For Each oSubAsm In allSubAsms
EnsureParamsExist(oSubAsm, paramsData)
Next
Dim allSubParts As List(Of Document) = doc.AllReferencedDocuments.Cast(Of Inventor.Document).Where(Function(d) d.DocumentType = DocumentTypeEnum.kPartDocumentObject).ToList
If allSubParts Is Nothing OrElse allSubAsms.Count = 0 Then Exit Sub
For Each part In allSubParts
Try
CopyUserParameters(doc, part)
Catch ex As Exception
MsgBox("Problems while making parameter copies to part: " & part.DisplayName)
End Try
Next
If doc.RequiresUpdate Then doc.Update2(True)
End Sub
Public Sub CopyUserParameters(sourceDoc As AssemblyDocument, targetDoc As PartDocument)
Dim sourceParameters As UserParameters = sourceDoc.ComponentDefinition.Parameters.UserParameters
Dim targetParameters As UserParameters = targetDoc.ComponentDefinition.Parameters.UserParameters
Dim targetParametersList As List(Of UserParameter) = targetDoc.ComponentDefinition.Parameters.UserParameters.Cast(Of UserParameter).ToList()
For Each source As UserParameter In sourceParameters
If (targetParametersList.Contains(source)) Then
Dim newParameter = targetParameters.Item(source.Name)
newParameter.Expression = source.Expression
newParameter.ExposedAsProperty = True
Else
Dim newParameter = targetParameters.AddByExpression(source.Name, source.Expression, source.Units)
' iLogicVb.UpdateWhenDone = True
End If
Next
End Sub
Sub EnsureParamsExist(oDoc As Document, oParamsData As List(Of List(Of Object)))
If oDoc Is Nothing Or (oParamsData Is Nothing OrElse oParamsData.Count = 0) Then Exit Sub
If oDoc.IsModifiable = False Then Exit Sub
Dim oUParams As UserParameters = oDoc.ComponentDefinition.Parameters.UserParameters
For Each MainEntry In oParamsData
If MainEntry.Count = 0 Then Continue For
Dim oUParam As UserParameter = Nothing
Try
oUParam = oUParams.Item(MainEntry.First)
Catch
oUParam = oUParams.AddByExpression(MainEntry.First, MainEntry.Item(1), MainEntry.Last)
End Try
Try
If Not oUParam.ExposedAsProperty Then oUParam.ExposedAsProperty = True
Dim oCPF As CustomPropertyFormat = oUParam.CustomPropertyFormat
oCPF.Units = oDoc.UnitsOfMeasure.GetStringFromType(MainEntry.Last)
oCPF.Precision = CustomPropertyPrecisionEnum.kThreeDecimalPlacesPrecision
oCPF.ShowLeadingZeros = True
oCPF.ShowTrailingZeros = True
Catch
End Try
Next
End Sub
Jelte de Jong
Blog: hjalte.nl - github.com
