Add own properties in Title Block?
How to add my own properties-tags to the catalog and having those to change in iProperties? For exemple: "number of parts" "phone" "material" (yes it does exist, but then it takes the material of the model and I maybe want to set more specific information) and mabye some more.
Depends where you want the properties to come from. Either custom properties in parts/assemblies or in the drawing template itself.
bretrick30
If the property you want is in the part/assembly, if you place a part or assembly that contains that property on the sheet then edit the definition of the titleblock those properties will show up when set the Type to "Properties - Model".
Yes I know that. What I want to do is to add my own properties to the program. Properties that you can't find in either Model or Drawing. And I want to have the opportunity to change those properties where you change properties in Drawing, namely under iProperties. I simply want to add custom properties in Drawing.
bretrick30
In the Custom Tab in the iProperties window, that is where you can create Custom iProperties.  In this picture are my Custom iProperties that I have show up on our title blocks.  These are in my part files, but you can create Custom iProperties in Drawings and Assemblies too.
