add new ipart when length is over a given value
Hello.
i have a inventor layout model with ilogic that is controlled by ilogic form where i insert and suppress different parts. And now i would like to add an ipart of a pipe that we use, The pipe is Ø50 and up to 6000mm long at max.
The layout can sometimes be 8500mm or bigger. ( never under 6000mm) Normaly i would add the ipart at 6000 and then 2500mm. is there a way to make ilogic add the parts or change length of the parts when the layout changes?
Example: I edit my form of the layout to 15000mm long, and when i press ok, i would like ilogic to add two pipes of 6000mm and one on 3000mm. even better if it was possible to get the lengt of the custom pipe in the properties.
hopefully you understand what i am looking for.
Best regards Kim
