Add new family to content centre library
kresh.bell
kresh.bell
is it possible create iLogic for create new column name, column caption, expression and map to properties. I have my custom content centre library with my columns, planty time I need for create all my custom columns each time when i want add new family to library
CCarreiras
Hi!
I don't think so.
I'm not aware that the software API have code to do such kind of things.
CCarreiras
kresh.bell
thanks
Andrii_Humeniuk
Hi @kresh.bell . I will say right away that I have never done this, but it seems possible, at least the API has the necessary functionality. I also found several examples of work in ContentCenter (link, link, link), but according to your request, I did not find it.
Below is an example of adding a column to your library:
Dim oInvApp As Inventor.Application = ThisApplication
oInvApp.ContentCenter.TreeViewTopNode.ChildNodes(9).ChildNodes(1).Families(1).TableColumns.Add(InternalName As String,
																								DisplayHeading As String,
																								DataType As ValueTypeEnum,
																								[Units] As Variant ,
																								[Expression] As Variant ,
																								[PropertySetId] As Variant ,
																								[PropertyIdentifier] As Variant )
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
mikejones
I have exactly the same issue with creating new families in content centre. It would be great to be able to import an XML or csv file that contained the new column names etc. It's such a ball ache doing this manually over and over again.
Autodesk Certified Professional
