add ins
add ins
add ins
Somebody please explain to me how this works below ... I want the revision cloud tool, intalled the .msi, and nothing???
wikihelp.autodesk.com
"Comments2
JmetalFri Mar 22, 2013 10:42 am
Am I correct in my understanding that there is not an easy way to create revision clouds?
paul.normandFri Mar 22, 2013 11:52 am
Hi Jmetal,
You are correct that it is not part of the default install. However, we do provide an optional install that does create a revision cloud. Go to C:\Users\Public\Documents\Autodesk\Inventor 2013\SDK and install the UserTools.msi. After installation, click the AddIns tab when you are in a drawing and the Revision Cloud command is available in the Drawing Tools panel.
Cheers,
Paul (autodesk)"
jdkriek
Not sure why it's not working for you. Ran .msi as admin and restarted?
It should appear under add-ins > drawing tools > in a drawing
I have it working in 2012, 2013, and 2014 - it's not great, but it works.
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Hey,
I got it to work. Apparently I needed administrative access to complete the install.
Thanks for the reply.
jdkriek
Yes you do 😉
Glad you got it working.
Jonathan D. Kriek
