For C++, I think it requires a little bit more work and a bit hesitant to
suggest copying template files because it might end up being a little
difficult to reverse it if things go wrong. But, since you have already
isntalled the wizard for VS 2005, hopefully copying only the template files
will work.
The templates are placed in subfolders of the folder specified by
HKLM\SOFTWARE\Microsoft\VisualStudio\8.0\Setup\VC\ProductDir
Under the folder mentioned by the above registry key, you will find the
following:
VCAddClass (folder)
+ Inventor (folder)
inventor.vsdir
InvEvents.ico
InvEvents.vsz
vcprojects (folder)
InvAppWiz.ico
InvAppWiz.vsdir
InvAppWiz.vsz
You can copy the above mentioned files to the corresponding VS2008 folders.
I myself don't have VS 2008 and can't guarantee that it will work, so if
you're willing to take the risk to try it out, then you can give it a shot.
-Venkatesh.
wrote in message news:5918746@discussion.autodesk.com...
Venkatesh, thanks for your reply
I only have access to the Express edition of 2005, will the installer work
with it?
Edit: I installed VS Express 2005, installed the wizards, and then copied
over the files to VS2008 folder and it works.
However, I see there are no templates for C++ which is what I really need.
Is there any way I can get a template file for a C++ add-in for Autodesk
Inventor?
Message was edited by: project6
