Add-In Issue - Plugin Unloading Automatically in Inventor 2021
vishnu_gaddime
vishnu_gaddime
 I've created an add-in for Autodesk Inventor 2021 using the Add-In template, and I'm using .NET Framework 4.8 for the development. When I run my project from Visual Studio, the plugin loads perfectly into Inventor and functions as expected and my build path is set to the location (C:\ProgramData\Autodesk\Inventor 2021\Addins). However, when I place the addin file and DLL in the designated directory (C:\ProgramData\Autodesk\Inventor 2021\Addins), and then open Inventor, I encounter an issue. The plugin appears as "unloaded," and when I attempt to load it manually, it automatically unloads again.
I would greatly appreciate it if someone could provide insights into why this issue might be occurring and how to resolve it.
FINET_Laurent
Hi @vishnu_gaddime,
I had similar behaviour when uploading an addins on different computers for each drafters. Have you had a check at your project references ? One was missing on some computers.
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
