Add In icons
Add In icons
Add In icons
I've been following the same rules with regard to the colour of my icons as
those of the bitmaps we use for macro buttons, however when used for an
icon, the pink turns out black, How do we get a transparent background to
our add ins?
Scott
The Picture you use for a icon has to have its transparency set. In Paint Shop Pro there
is a option when saving a graphics file to gif and bmp I think that you can set one pallet
color to transparent.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Scott" wrote in message
news:63BA205AE9EA50D9E26605CF19BA02C8@in.WebX.maYIadrTaRb...
> Hello,
> our add ins?
> Thanks
> Scott
I've always just set the background to the normal gray color (I guess
however of course if people tweak their default settings in Windows this
could cause problems)
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Kent Keller" wrote in message
news:A6D2493754CAFF56D0DE501C9B098EE1@in.WebX.maYIadrTaRb...
can set one pallet
> Kent
> Assistant Moderator
> > Hello,
as
to
> > our add ins?
> > Thanks
> > Scott
For icons, you must use Magenta as the background color (RGB 255,0,255) to
be transparent and for images (i.e. on buttons) the lower left pixel becomes
the transparent color.
Mike
__________________
Michael V. Ficarra
Engineering Manager
Cross Bros. Co. Inc.
(585) 427-7850 x207
(585) 427-2908 (Fax)
(585) 233-6653 (Cell)
www.crossbros.com
"Sean Dotson" wrote in message
news:39F6CCD6136D6BE228F3F9A77968AF05@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
> can set one pallet
> > Kent
> > Assistant Moderator
> > > Hello,
icons
> as
an
background
> to
> > > our add ins?
> > > Thanks
> > > Scott
It is not necessary to use Magenta. Most of the tool icons on the
bottom of KWiKViews have gray backgrounds but you don't see the gray
when they are inserted into the form.
Here is the Save Option dialog in Paint Shop Pro 4. You can see that
you can set transparency to any 1 color you want.
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
Assistant Moderator
"Mike Ficarra" wrote in message
news:B7C409B04292BC529409A835A3A97CE4@in.WebX.maYIadrTaRb...
255,0,255) to
becomes
