Add-in: Do something after inventor activation
I know you can do some event in a VB add-in in the "Public Sub Activate" but can you do some event after Inventor has fully loaded and the interface is fully loaded?
jeff.pek
Hi -
You should be able to use the ApplicationEvents.OnReady event for this.
Jeff
Only need to do it the first time Inventor loads though. Make sense?
jeff.pek
Yes. You'll only see that event once in a session.
What are you trying to synchronize?
Jeff
Oh, well that will work then... thanks for the help. Synchronize? Your on to something. I'll post more when I can prove it works.
