Add Images into Addins for display on Ribbon button
Hello Team,
I have created Add ins for Inventor and added buttons and their images on ribbon.
But I have created folder into following path and pasted images into that folder because Inventor by default taking this path.
C:\Program Files\Autodesk\Inventor 2019\Bin\
But now I am trying to create Add ins which by default take Images from our C# solution not from any other location. (means I want Images added into Addins itself so I don't need to put manually any other location )
can you help me to find out solution of this problem?
dgreatice
 did you mean icon button?
use image resources.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Hello
Thank you for your reply.
Yes, I want icon button which icons into add ins itself.
Please help me for how to use image resources into Inventor add ins
dgreatice
First,
install developertools in:
C:\Users\Public\Documents\Autodesk\Inventor 2019\SDK
after installing, check in Visual studio:
File>New>Project
are there Autodesk Inventor 2019 Addin template installed?
Yes, I have developed Addins into Inventor 2019 Addins template
dgreatice
No, I mean after install developertools, you will be get default Autodesk Inventor 2019 AddIn template.
inside that template, you can learn how to using resource image.
dgreatice
