add external ilogic rule to event trigger by using external ilogic rule
i had created one external rule "Plate" and i want to add this rule to all individual parts by using ilogic/API
clutsa
Could you use the built in feature in event triggers to add it to all parts?
Manage tab>iLogic>Event Triggers
Go to the parts tab and drag your rule from the left column to the right under what event you want to trigger the  external rule.
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
