Add Description next to arraylist item?
bbrumfield
Message 1 of 9
bbrumfield
I have a situation where I've created a rule to return the a material stock code from an ArrayList, the problem is I also need to see the stock code description to make the correct selection.
Dim oDoc As Document = ThisDoc.Document
Dim CustTypeCRS As New ArrayList
CustTypeCRS.Add("ME-CRS-0006")'22GA, Sheet, Cold Rolled Steel, 60.00 x 120.00
CustTypeCRS.Add("ME-CRS-0009")'16GA, Sheet, Cold Rolled Steel, 60.00 x 120.00
CustTypeCRS.Add("Me-CRS-0010")'20GA, Sheet, Cold Rolled Steel, 60.00 x 120.00
CustTypeCRS.Add("ME-CRS-0011")'18GA, Sheet, Cold Rolled Steel, 60.00 x 120.00
CustTypeCRS.Add("ME-CRS-0013")'14GA, Sheet, Cold Rolled Steel, 60.00 x 120.00
Dim oSelMaterialStockCode As String = InputListBox("Select Material Stock Code", CustTypeCRS, oMaterialStockCode, Title := "CRS Sheet Selection", ListName := "CRS Sheet Stock Code")
'if this custom property doesn't exist, this next line will also crete it if needed (no error shown)
iProperties.Value("Custom", "Material Stock Code") = oSelMaterialStockCode
Accepted solutions (3)
Replies (8)
Message 2 of 9
dalton98
Edit: This is not what you were asking lol
I would add another value to list for none
CustTypeCRS.Add("none")
Then before the imputlistbox put this
Try
oMaterialStockCode = iProperties.Value("Custom", "Material Stock Code")
Catch
oMaterialStockCode = "none"
End Try
 Also you could just have the tile of the list be the current stock code instead of "Select Material Stock Code". Then you wouldn't have to add another list value and the title would either be blank or give the previous value.
Hope this is what you were asking.
Message 3 of 9
Curtis_W
Hi @bbrumfield,
You can add them together with a delimiter (in this case a vertical bar "|") and then use the Split function to create an array from the selection, and only use the part number portion of the array for the iproperty value. See example below.
I hope this helps.
Curtis
CustTypeCRS.Add("22GA, Sheet, Cold Rolled Steel, 60.00 x 120.00 | ME-CRS-0006")
CustTypeCRS.Add("16GA, Sheet, Cold Rolled Steel, 60.00 x 120.00 | ME-CRS-0009")
CustTypeCRS.Add("20GA, Sheet, Cold Rolled Steel, 60.00 x 120.00 | Me-CRS-0010")
	CustTypeCRS, oMaterialStockCode, Title := "CRS Sheet Selection", _
sSplit = Split(oSelMaterialStockCode, "|")
oDesc = sSplit(0)
oPN = sSplit(1)
'if this custom property doesn't exist, this next line will also create it if needed (no error shown)
iProperties.Value("Custom", "Material Stock Code") = oPN
MsgBox(iProperties.Value("Custom", "Material Stock Code") )
Message 4 of 9
petr.meduna
Just add the description to array list and then separate the selection via char you choose. For example:
CustTypeCRS.Add("ME-CRS-0006/22GA, Sheet, Cold Rolled Steel, 60.00 x 120.00")
CustTypeCRS.Add("ME-CRS-0009/16GA, Sheet, Cold Rolled Steel, 60.00 x 120.00")
CustTypeCRS.Add("Me-CRS-0010/20GA, Sheet, Cold Rolled Steel, 60.00 x 120.00")
CustTypeCRS.Add("ME-CRS-0011/18GA, Sheet, Cold Rolled Steel, 60.00 x 120.00")
CustTypeCRS.Add("ME-CRS-0013/14GA, Sheet, Cold Rolled Steel, 60.00 x 120.00")
Dim oSplit() As String = Split(oSelMaterialStockCode, "/")
iProperties.Value("Custom", "Material Stock Code") = oSplit(0)
Message 5 of 9
bbrumfield
Works Perfectly!
Brent
Message 6 of 9
Michael.Navara
More sophisticated solution is to use custom object (class) for items. See the following sample code
Sub Main
	Dim items As New List(Of ListItem)
	items.Add(New ListItem("1", "One") )
	items.Add(New ListItem("2", "Two") )
	items.Add(New ListItem("3", "Three"))
	Dim selectedItem = InputListBox("Select value", items)
	Logger.Debug(selectedItem.Value)
End Sub
Class ListItem
	Public Sub New(value As String, displayName As String)
		Me.Value = value
		Me.DisplayName = displayName
	End Sub
	Public Property Value As String
	Public Property DisplayName As String
	Public Overrides Function ToString() As String
		Return DisplayName
	End function
End Class
Message 7 of 9
bbrumfield
Hi Michael,
Thank you, I will test. I think from what I see and please correct me if I'm wrong. The attached code appears to allow the rule to be selected multiple times creating a new custom for ea.?
Brent F. Brumfield
Director of Engineering
P: (513) 385-0555
M: (513) 309-6643
bbrumfield@arscometals.com
www.arscomfg.com
[cid:image001.png@01D84F1D.09510460]
Message 8 of 9
bbrumfield
Hi Michael,
I tested the code you attached and must be doing something incorrectly, the code ran without error but produced no results.
Brent
Message 9 of 9
Curtis_W
Hi @bbrumfield ,
That example uses the iLogic Logger to show the result. You can use this modified example to see the result in a message box.
More about the iLogic Logger, if interested:
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Inve...
I hope this helps.
Curtis
Sub Main
	Dim oList As New List(Of ListItem)
	oList.Add(New ListItem("1", "One") )
	oList.Add(New ListItem("2", "Two") )
	oList.Add(New ListItem("3", "Three"))
	Dim selectedItem = InputListBox("Select value", oList)
	'Logger.Debug(selectedItem.Value)
	MsgBox(selectedItem.Value,,"iLogic")
End Sub
Class ListItem
		Me.Value = value
	End Sub
		Return DisplayName
	End Function
End Class
