Hello.
I've managed to achieve my goal and get the illogic code working as I needed it to.
Thanks for the initial push.
- This code first checks if a virtual component already exists in the assembly. If it does, it updates its Part Number, Description, and User Defined Properties.
- If the virtual component doesn't exist, it creates a new one using the Part Number, Description, and custom properties from the active assembly.
' Get the active document (must be an assembly)
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
' Check if the active document is really an assembly
If oDoc.DocumentType <> kAssemblyDocumentObject Then
MessageBox.Show("The active document is not an assembly.")
Exit Sub
End If
' Get the definition of the active assembly component
Dim oCompDef As AssemblyComponentDefinition
oCompDef = oDoc.ComponentDefinition
' Get the Part Number and Description of the active assembly
Dim oPartNumber As String
oPartNumber = oCompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
Dim oDescription As String
oDescription = oCompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Description").Value
' Get the name of the active assembly to rename the virtual component
Dim oAssemblyName As String
oAssemblyName = oDoc.DisplayName ' DisplayName includes the file extension
' Remove the extension (.iam) from the file name to use as the virtual component name
oAssemblyName = Left(oAssemblyName, InStrRev(oAssemblyName, ".") - 1)
' Create a default transformation (position) matrix
Dim oMatrix As Matrix
oMatrix = ThisApplication.TransientGeometry.CreateMatrix()
' Search directly for virtual components, ignoring names
Dim oVirtualOccurrence As ComponentOccurrence = Nothing
Dim oOccurrence As ComponentOccurrence
Dim found As Boolean = False
' Iterate through the occurrences in the assembly
For Each oOccurrence In oCompDef.Occurrences
' Check if the occurrence is a virtual component
If TypeOf oOccurrence.Definition Is VirtualComponentDefinition Then
' Virtual component found
oVirtualOccurrence = oOccurrence
found = True
Exit For
End If
Next
' If the virtual component already exists, update its properties
If found Then
' Update the properties of the existing virtual component
Dim oVirtualCompDef As VirtualComponentDefinition
oVirtualCompDef = oVirtualOccurrence.Definition
' Update the Part Number
oVirtualCompDef.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = oPartNumber
' Update the Description
oVirtualCompDef.PropertySets.Item("Design Tracking Properties").Item("Description").Value = oDescription
' Get the User Defined Properties of the active assembly
Dim oUserDefinedProps As PropertySet
oUserDefinedProps = oCompDef.Document.PropertySets.Item("User Defined Properties")
' Iterate through the User Defined Properties of the active assembly and copy them to the virtual component
Dim oProp As Inventor.Property
For Each oProp In oUserDefinedProps
Try
' Try to access and replace the property if it exists
oVirtualCompDef.PropertySets.Item("User Defined Properties").Item(oProp.Name).Value = oProp.Value
Catch ex As Exception
Try
' If the property doesn't exist, add it
oVirtualCompDef.PropertySets.Item("User Defined Properties").Add(oProp.Value, oProp.Name)
Catch addEx As Exception
' Handle exceptions when adding the property
MessageBox.Show("Error adding the property: " & oProp.Name & " - " & addEx.Message)
End Try
End Try
Next
' Display a message indicating that the virtual component has been successfully updated
MessageBox.Show("The virtual component's custom properties and description have been successfully updated!")
Else
' If the virtual component does not exist, create a new virtual component
Try
oVirtualOccurrence = oCompDef.Occurrences.AddVirtual(oAssemblyName, oMatrix) ' Use the assembly name here
' Assign the Part Number and Description to the new virtual component
Next
' Display a message indicating that the virtual component has been successfully created
MessageBox.Show("Virtual component created and renamed to: " & oAssemblyName & " with the same Part Number, description, and custom properties as the active assembly!")
MessageBox.Show("Error creating the virtual component: " & ex.Message)
Exit Sub
End Try
End If
