Add Content Center Part in External Rule with variable.
donald_leigh
donald_leigh
Hi all
I have a rule that I need help with, When adding and changing a CC part the following rule works but when I change the "Designation" value ("Simplex-20") to either a user parameter or a variable string I get an error. How can I get the "Designation" value to change based on other factors.
Donald
Components.ContentCenterLanguage = "en-US"
Dim PLATEWHEEL = Components.AddContentCenterPart("Sprocket" & SprocketNumber,
                                                 "Transmission Chains:Sprockets",
                                                 "PLATEWHEEL BS 1"" PILOT BORE",
                                                 "Simplex-20")
C_Haines_ENG
Could you post the code you are using that has "Simplex-20" set as a variable?
