Add all dirty documents to browserpanes
GeorgK
Advisor Advisor
GeorgK
Hello together,
how could I add all dirty documents to a browser pane?
Thank you Georg
xiaodong_liang
Autodesk Support
Autodesk Support
Hi Georg,
can I understand you want to add the part/sub-assembly nodes (the corresponding document is dirty) to your own browerpane (custom pane) ?
GeorgK
Hello Xiaodong,
Yes that's it what I want to do.
Georg
xiaodong_liang
Autodesk Support
Autodesk Support
Hi Georg,
you just need to iterate the occurrences of assembly document and get which one is dirty, and add them to your browser pane.
The below is a blog on how to create custom browser pane. It shows adding an Inventor document node to the custom pane.
http://adndevblog.typepad.com/manufacturing/2013/07/add-a-new-custom-pane-and-add-node-from-a-defaul...
As to iterate occurrences, the code could be:
Sub test()
    Dim oDoc  As AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oAssDef As AssemblyComponentDefinition
    Set oAssDef = oDoc.ComponentDefinition
    Dim oOcc As ComponentOccurrence
    Dim oEachDoc As Document
    For Each oOcc In oAssDef.Occurrences
        Set oEachDoc = oOcc.Definition.Document
        If oEachDoc.Dirty = True Then
            'Add it to your browser pane
        End If
    Next
End Sub
GeorgK
Hello Xiaodong,
the problem is not to loop through the assembly and find the dirty files. But how could I add them to the browserpane or change the icon from files which are dirty?
Thank you Georg
xiaodong_liang
Autodesk Support
Autodesk Support
Hi Georg,
may I know whether you have taken a look at that blog link I posted in the last message? it exactly shows how to add a document to the custom browser pane.
As to change the icon of the browser node, please refer to the two blogs below. Although it is talking about client feature, it is similar to change the icon. i.e. the core codes are:
  ‘create the resource of icon. assume a bitmap 1.bmp exists  ‘ in c:\temp
        Dim oCnr As ClientNodeResource
        Dim oIcon As IPictureDisp
        Set oIcon = stdole.LoadPicture("C:\temp\1.bmp")
        ' Create a client node resource.
        Set oCnr = oDoc.BrowserPanes.ClientNodeResources.Add("SamplePocketFeature", -1, oIcon)
        ' Override the icon for the client feature.
        oNode.BrowserNodeDefinition.OverrideIcon = oCnr
http://adndevblog.typepad.com/manufacturing/2015/01/change-icon-of-clientfeature-node-in-built-in-br...
http://adndevblog.typepad.com/manufacturing/2012/08/change-the-browser-node-icon.html
