Active Thread feature in Drawing in Display option tab
Pratik.Ksoni
Message 1 of 9
Pratik.Ksoni
i need to active thread feature in inventor drawing file, i have so many drawing sheets and i want to change display state individually. is there any rule to macro that can turn on thread feature in drawing?
Please help me.
Replies (8)
Message 2 of 9
dgreatice
iLogic Version
try this:
Dim oApp As Application
    Dim oDD As DrawingDocument
    Dim oSht As Sheet
    Dim oDV As DrawingView
    oApp = ThisApplication
    oDD = oApp.ActiveDocument
    For Each oSht In oDD.Sheets
        For Each oDV In oSht.DrawingViews
            oDV.DisplayThreadFeatures = True
        Next
    Next
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Message 3 of 9
Pratik.Ksoni
how to change color of Thread feature in drawing?
Pratik
Message 4 of 9
dgreatice
First,
I want check you drawing.
1. Select thread edge.
2. Identify, layer Name is?
Message 5 of 9
Pratik.Ksoni
i tried with change layer color and it works but many of line has same layer so once i change thread layer then it takes all edges color. so using i logic i have created new layer and set the color and want to give same new layer color to thread feature.
i hope it can clear.
Thanks in advance.
Cheers!!
Message 6 of 9
dgreatice
By default, thread edge save in Layer with name Visible Narrow (ISO).
so update my code,
    Dim oLayer As Layer
    oLayer = oDD.StylesManager.Layers.Item("Visible Narrow (ISO)")
    Dim MyColor As Color
    MyColor = oApp.TransientObjects.CreateColor(255, 0, 0)
    oLayer.Color = MyColor
Message 7 of 9
Pratik.Ksoni
See Below rule which i have applied to copy new layer and set color of this layer.
now i want to set this new layer color to thread feature only.
SyntaxEditor Code Snippet
        oDD = ThisApplication.ActiveDocument
        Dim oL As Layer
        oL = oDD.StylesManager.Layers("Hidden (ISO)").Copy("Thread Line")
        Dim oC As Inventor.Color
        oC = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
        Call oC.SetColor(255, 0, 0)
        oL.Color = oC
Pratik
Message 8 of 9
Pratik.Ksoni
highlighted line has same layer name but i only want to change thread feature color change.
Message 9 of 9
dgreatice
I think it must be difference, between VISIBLE (ISO) and VISIBLE NARROW (ISO)
Visible (ISO) are normal line/edge
Visible Narrow (ISO) are Thread line/edge
maybe you wrong about that.
