Active document if editing a iam
Hello!
suppose i have a IAM open, the active document is the iam.
Then i doubleclick a IPT in it, so it can be edited.. this event is then fired:
Private Sub oAppEvents_OnActivateDocument(DocumentObject As _Document, BeforeOrAfter As EventTimingEnum, Context As NameValueMap, ByRef HandlingCode As HandlingCodeEnum) Handles oAppEvents.OnActivateDocument
            'fire after document Is made active
            If BeforeOrAfter = EventTimingEnum.kAfter Then
                fillfields(DocumentObject)
            End If
        End Sub
Problem is that the active document remains the main IAM and not the part I am editing. How can i retrive the part I am editing from within this sub?
Thank you!
marcin_otręba
try use ActiveEditDocument instead...
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
