Active different FlatPatternOrientation object through iLogic
L.Greft
L.Greft
I'm working on parametric models and in some parts we also use splits. The problem I'm facing now is that the part I'm working on can have a horizontal split or a vertical split. The flat pattern has an alignment axis by default (in my case) set on a horizontal line, which is fine. But when I turn on the horizontal split the top of the part needs to be deleted, but the alignment axis is also placed here and causes an error. Because the edge/axis is not found.
So I wanted to add a second orientation named "Split" that is activated when the horizontal split is unsuppressed. I searched within the API help and came across the object "FlatPatternOrientation" which has a method named "Activate". I tried the following code, but it didn't work because it has to many arguments.
sheetMetalDef.FlatPattern.FlatPatternOrientations.ActiveFlatPatternOrientation.Activate("Split")
Can someone help me with this, please? Below is a photo that will (hopefully) make it easier to understand what my goal is.
Inventor 2021
Check out my ideas: https://autode.sk/2TKe6LH
dalton98
Something like this might be what your after...
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
Dim oFeature As PartFeature
For Each oFeature In oDoc.ComponentDefinition.Features
If oFeature.Type = ObjectTypeEnum.kSplitFeatureObject And oFeature.Suppressed = False
Dim sheetMetalDef As SheetMetalComponentDefinition
sheetMetalDef = oDoc.ComponentDefinition
Try
sheetMetalDef.Unfold
sheetMetalDef.FlatPattern.FlatPatternOrientations.Item(2).Name = "Split"
sheetMetalDef.FlatPattern.FlatPatternOrientations.Item(2).AlignmentType = AlignmentTypeEnum.kVerticalAlignment
sheetMetalDef.FlatPattern.FlatPatternOrientations.Item(2).Activate
Catch
sheetMetalDef.FlatPattern.FlatPatternOrientations.ActiveFlatPatternOrientation.Copy
End Try
End If Next
L.Greft
@dalton98 thank you for the response! I tried it and it didn't exactly worked like I expected, when the split is active it does work, but there is no alignment axis selected. But the good thing is that it doesn't result in an error and the flat pattern can still be made.
Thank you for the help!
