Accessing parameters from an Excel spreadsheet
This code comes from IV samples illustrating how to access values from an Excel file. When I use it I get "Type Mismatch" error. Is anyone using this functionality and if so what must be changed to make it work?
Public Sub TableParameters()
Dim oPartDoc As Inventor.PartDocument
' Obtain the active document, this assumes that
' a part document is active in Inventor
Set oPartDoc = ThisApplication.ActiveDocument
'Obtain the Parameters collection
Dim oParams As Parameters
Set oParams = oPartDoc.ComponentDefinition.Parameters
' Add a parameter table using an existing spreadsheet.
oParams.ParameterTables.AddExcelTable "C:\Temp\params.xls", "A1", True
' Accessing a parameters in a linked/embedded file
Dim oParamTableFiles As ParameterTables
Set oParamTableFiles = oParams.ParameterTables
' Traverse through the collection of linked files
Dim oParamTableFile As ParameterTable
For Each oParamTableFile In oParamTableFiles
' Change the linked file to another file
If LCase(oParamTableFile.FileName) = "c:\temp\params.xls" Then
oParamTableFile.FileName = "C:\Temp\newparams.xls"
End If
' Get the Parameters collection from the file
Dim oTableParams As TableParameters
Set oTableParams = oParamTableFile.TableParameters
' Traverse through the table parameters collection and display them
Dim iNumTableParams As Long
Debug.Print "TABLE PARAMETER VALUES"
For iNumTableParams = 1 To oTableParams.Count
' Display the name
Debug.Print " Name: " & oTableParams.Item(iNumTableParams).Name
' Display the expression
Debug.Print " Expression: " & oTableParams.Item(iNumTableParams).Expression
' Display the value. This will be in database units.
Debug.Print " Value: " & oTableParams.Item(iNumTableParams).Value
Next iNumTableParams
Next
End Sub
Jon
When you get an runtime error msg box, click on the debug button and it will
show you where the error is (yellow highlight)
CVA
www.CVAengineering.com
IV11 Pro. sp2 and IV2008
Window XP Pro sp2
Pentium 3.2 Ghz, 3.0 GB of RAM
NVIDIA FX 3400 91.85
SpacePilot V 3.3.6
wrote in message news:5630689@discussion.autodesk.com...
End If
' Display the name
Next
End Sub
Jon
This is the highlighted line of code, but what does this tell me? I have an active document .xls with the name params, just as the path indicates in the code. Is it the variable type in the file which is being questioned??
Jon
I guess you declared your active document as a part document and run the
program while an assembly is active?
CVA
Window XP Pro sp2
SpacePilot V 3.3.6
wrote in message news:5630961@discussion.autodesk.com...
Jon
