Accessing Iproperties without opening part
I am trying to create an add-in to take an assembly and export a top level BOM to excel that includes some custom properties.  I am not really sure how to do this.
I have done the following
Occurrences = DocumentObject.ComponentDefinition.Occurrences
Dim oOcc As ComponentOccurrenceDim Occurrences As ComponentOccurrencesFor Each oOcc In Occurrences
MsgBox(oOcc.Name)
MsgBox(oOcc.ReferencedDocumentDescriptor.FullDocumentName)
Next
Which displays the name and full path of the files I want.  I am not sure how to get from her to accessing the custom iproperties without opening each part.  I don't want to open each component as it will use too much resources.
Any ideas on where to go from here would be greatly appreciated.
jeff.pek
Hi -
Have you measured the memory impact of accessing the component's iProperties? I'd suspect that there isn't significant additional impact, given that these documents are open, anyway, by virtue of opening their containing assembly.
Jeff
Thanks, had not thought of the fact they are already open in a sense. How would I go from the code above to opening parts to access the iproperties. I am at a bit of a loss how to go from an Occurance reference to opening the actual part or assembly.
jeff.pek
Sure. You can access the iProperties of the component documents from their ComponentDefinitions, as in:
  Dim oPropertySets as PropertySets
  set oPropertySets = occ.ReferencedDocumentDescriptor.ReferencedDocument.PropertySets
You could also access it via its definition:
  occ.Definition.Document.PropertySets
I doubt that either one of these is any more or less efficient than the other.
One thing to watch out for: "missing" references, if they happen to be unresolved or unloaded (via an LOD).
Jeff
