Access to 3D-sketch curve in 2D-drawing view
artemijs.nille
artemijs.nille
I have a curve in 2D-drawing view that was created in the sketch of a 3D-modell(see picture below).
My goal is to put a diameter dimension by iLogic automaticaly.
How can access this curve?
basautomationservices
You can retrieve the model geometry of a curve like this:
Dim activeSheet As Sheet
activeSheet = ThisApplication.ActiveDocument.activeSheet
Dim crv As DrawingCurveSegment
crv = ThisApplication.CommandManager.Pick(kDrawingCurveSegmentFilter, "pick curve")
Dim dwgCrv As DrawingCurve
dwgCrv = crv.Parent
Dim modelGeom As Object
modelGeom = dwgCrv.ModelGeometry
Contact me for custom app development info@basautomationservices.com. Follow below links to view my Inventor appstore apps.
Free apps: Smart Leader | Part Visibility Utility | Mate Origins
Paid apps: Frame Stiffener Tool | Constrain Plane Toggle | Property Editor Pro
artemijs.nille
Thank you for a reply.
In your sollution i have to pick the curve manually.
How can i retrieve this curve automatically (like "GetIntent").
And how can i add a diameter dimesnion by iLogic.
It should work like this:
Dim Sheet_1 = ThisDrawing.Sheets.ItemByName("Sheet:1")
Dim VIEW1 = Sheet_1.DrawingViews.ItemByName("VIEW1")
Dim genDims = Sheet_1.DrawingDimensions.GeneralDimensions
Dim holeDim = genDims.AddDiameter("Hole Diameter", VIEW1.SheetPoint(0.25, 0.45), VIEW1.GetIntent("HoleFace"))
and i have to get Intent from my sketch curve
