access the sketch consumed by an feature
Message 1 of 9
i Know how to acces  all features in other  and i know how to access all sketches in other but is posible to acces to the sketch of a feature ?
Replies (8)
Message 2 of 9
JhoelForshav
Hi @Anonymous
I assume you mean the sketch containing the profile for the feature?
For example the extruded profile in an extrude feature.
You'll have to get the profile and then its parent.
Dim oFeature As PartFeature = ThisDoc.Document.ComponentDefinition.Features(1)
Dim profileSketch As PlanarSketch = oFeature.Profile.Parent
MsgBox(profileSketch.Name)
Message 3 of 9
yes, i mean that , english is not mi habitual lenguage so i dont know how to explain some things of inventor . The code you put dosent works with out some modifications ,but the essence of the aswers yes, it helps me to solve mi problem ,
Message 4 of 9
and other problem is that it makes error message "No se encuentra el miembro público 'Profile' en el tipo 'HoleFeature'." how can i aboit that?
Message 5 of 9
JhoelForshav
Hi @Anonymous
HoleFeatures doesn't have profiles. They only have a sketch with points in it. It's easily accessed like through the HoleFeature.Sketch property.
Example:
Dim oFeature As HoleFeature = ThisDoc.Document.ComponentDefinition.Features.HoleFeatures(1)
Dim oSketch As PlanarSketch = oFeature.Sketch
MsgBox(oSketch.Name)
Message 6 of 9
there is any way to take the sketch independently if is a extrusion or a hole or any thing . i want to take the sketch to check the constrains
Message 7 of 9
JhoelForshav
Maybe something like this?
'Get the feature the way you want.
Dim oFeature As PartFeature = ThisDoc.Document.ComponentDefinition.Features("Extrusion1")
Dim oSketch As PlanarSketch If TypeOf (oFeature) Is HoleFeature oSketch = oFeature.Sketch ElseIf TypeOf (oFeature) Is RevolveFeature _ Or TypeOf (oFeature) Is SweepFeature _ Or TypeOf (oFeature) Is EmbossFeature _ Or TypeOf (oFeature) Is CoilFeature _ Or TypeOf (oFeature) Is ExtrudeFeature oSketch = oFeature.Profile.Parent End If MsgBox(oSketch.Name)
I didn't include Rib or Loft because they are more complex than just the one sketch...
Message 8 of 9
and a Rib ?
Message 9 of 9
JhoelForshav
Dim oFeature As PartFeature = ThisDoc.Document.ComponentDefinition.Features("Rib1")
ElseIf TypeOf (oFeature) Is RibFeature
	oSketch = oFeature.Definition.ProfileCurves(1).Parent
End If
