Sub Main()
Dim StartTime As DateTime
Dim ElapsedTime As TimeSpan
StartTime = Now
' Defining This Document
Dim oPartDoc As PartDocument = ThisApplication.ActiveDocument
'Definining a Component Definition
Dim oPartDef As PartComponentDefinition = oPartDoc.ComponentDefinition
Dim oParams As Parameters
oParams = oPartDef.Parameters
Dim oUserParams As UserParameters
oUserParams = oParams.UserParameters
Dim assetLib As AssetLibrary = ThisApplication.AssetLibraries.Item("Autodesk Appearance Library")
Dim oCircle(10) As SketchCircle
Dim oLine(20) As SketchLine
Dim oPrLine(20) As SketchLine
Dim oPoint(10) As SketchPoint
Dim oProjectionPoint(10) As SketchPoint
Dim oCon(10) As CoincidentConstraint
Dim oDim(10) As TwoPointDistanceDimConstraint
Dim oOffsetDim(6) As OffsetDimConstraint
Dim oAngDim(6) As TwoLineAngleDimConstraint
Dim oProfile(6) As Profile
Dim oExtrudeDef(0 To 6) As ExtrudeDefinition
Dim oExtrusion(6) As ExtrudeFeature
Dim oFillet(10) As FilletFeature
Dim oSkArc(10) As SketchArc
Dim oPrArc(10) As SketchArc
Dim oArcDim(10) As ArcLengthDimConstraint
Dim oAngleDim(10) As ThreePointAngleDimConstraint
Dim oRDim(0 To 6) As RadiusDimConstraint
Dim oTanDim(10) As TangentDistanceDimConstraint
Dim oRs(3) As RenderStyle
Dim oProximityPoint(10) As Point2d
Dim oProximityPoints(10) As Point
Dim ExtrudeFeatDistExtent(10) As DistanceExtent
'[ Create's a Profile Sketch
Dim oSketch(10) As PlanarSketch
oSketch(1) = oPartDef.Sketches.Add(oPartDef.WorkPlanes.Item(2))
oSketch(1).Name = "Base Profile Sketch"
'Collecting Transient Geometry
Dim tg As TransientGeometry
tg = ThisApplication.TransientGeometry
oRs(1) = oPartDoc.RenderStyles.Item("Default")
oRs(2) = oPartDoc.RenderStyles.Item("Shellac")
oRs(3) = oPartDoc.RenderStyles.Item("Red")
oPartDoc.ActiveRenderStyle = oRs(2)
oProjectionPoint(1) = oSketch(1).AddByProjectingEntity(oPartDef.WorkPoints.Item(1))
oLine(1) = oSketch(1).SketchLines.AddByTwoPoints(tg.CreatePoint2d(0, 6.25), tg.CreatePoint2d(0, - 6.25))
Call oSketch(1).GeometricConstraints.AddVertical(oLine(1))
oLine(2) = oSketch(1).SketchLines.AddByTwoPoints(oLine(1).EndSketchPoint, tg.CreatePoint2d(8.9325, -3.8565))
oLine(3) = oSketch(1).SketchLines.AddByTwoPoints(oLine(1).StartSketchPoint, tg.CreatePoint2d(8.9325, 3.8565))
oPrLine(1) = oSketch(1).AddByProjectingEntity(oPartDef.WorkAxes.Item(1))
oPrLine(1).Construction = True
Call oSketch(1).GeometricConstraints.AddCoincident(oLine(1), oProjectionPoint(1))
oSkArc(1) = oSketch(1).SketchArcs.AddByCenterStartEndPoint(tg.CreatePoint2d(2.5, 0), oLine(2).EndSketchPoint,oLine(3).EndSketchPoint,True)
Call oSketch(1).GeometricConstraints.AddVerticalAlign(oSkArc(1).StartSketchPoint, oSkArc(1).EndSketchPoint)
Call oSketch(1).GeometricConstraints.AddCoincident(oSkArc(1).CenterSketchPoint,oPrLine(1))
Call oSketch(1).GeometricConstraints.AddSymmetry(oLine(2),oLine(3),oPrLine(1))
oDim(1) = oSketch(1).DimensionConstraints.AddTwoPointDistance(oLine(1).StartSketchPoint,oLine(1).EndSketchPoint,DimensionOrientationEnum.kVerticalDim,tg.CreatePoint2d(-2.5,0))
oDim(1).Parameter.Expression = "d0=125"
oRDim(1) = oSketch(1).DimensionConstraints.AddRadius(oSkArc(1), tg.CreatePoint2d(7.5,- 1.7))
oRDim(1).Parameter.Expression = "d1=75mm"
oProximityPoint(1) = tg.CreatePoint2d(10.0, 0)
oProximityPoint(2) = tg.CreatePoint2d(0, 0)
oTanDim(1) = oSketch(1).DimensionConstraints.AddTangentDistance(oSkArc(1), oLine(1),oProximityPoint(1), oProximityPoint(2), tg.CreatePoint2d(5.00, -8.0), False)
oTanDim(1).Parameter.Expression= "d2=100"
oPoint(1) =oSketch(1).SketchPoints.Add(tg.CreatePoint2d(8.9325, -6.25))
Call oSketch(1).GeometricConstraints.AddHorizontalAlign(oLine(1).EndSketchPoint, oPoint(1))
Call oSketch(1).GeometricConstraints.AddVerticalAlign(oLine(2).EndSketchPoint, oPoint(1))
oAngleDim(1) = oSketch(1).DimensionConstraints.AddThreePointAngle(oPoint(1),oLine(1).EndSketchPoint,oLine(2).EndSketchPoint,tg.CreatePoint2d(10.8,-4.7))
oAngleDim(1).Parameter.Expression = "d3=15"
Call oSketch(1).Solve
'[ Create's a Revolve Sketch
oSketch(2) = oPartDef.Sketches.Add(oPartDef.WorkPlanes.Item(1))
oSketch(2).Name = "Revolve Surface Sketch"
oProjectionPoint(2) = oSketch(2).AddByProjectingEntity(oPartDef.WorkPoints.Item(1))
oLine(4) = oSketch(2).SketchLines.AddByTwoPoints(tg.CreatePoint2d(-12.0, -6.25), tg.CreatePoint2d(-12.0, 6.25))
Call oSketch(2).GeometricConstraints.AddVertical(oLine(4))
oLine(4).Construction = True
oLine(4).Centerline = True
oPoint(2) = oSketch(2).AddByProjectingEntity(oLine(1).StartSketchPoint)
oPoint(3) =oSketch(2).AddByProjectingEntity(oLine(1).EndSketchPoint)
Call oSketch(2).GeometricConstraints.AddHorizontalAlign(oLine(4).StartSketchPoint,oPoint(2))
Call oSketch(2).GeometricConstraints.AddHorizontalAlign(oLine(4).EndSketchPoint,oPoint(3))
oPrLine(2) = oSketch(2).AddByProjectingEntity(oPartDef.WorkAxes.Item(3))
oPrLine(2).Construction = True
oPrLine(3) = oSketch(2).AddByProjectingEntity(oPartDef.WorkAxes.Item(2))
oPrLine(3).Construction = True
oDim(2) = oSketch(1).DimensionConstraints.AddTwoPointDistance(oLine(4).StartSketchPoint,oPoint(2),DimensionOrientationEnum.kHorizontalDim,tg.CreatePoint2d(-7.4,11.5))
oDim(2).Parameter.Expression = "d4=120"
oSkArc(2) = oSketch(2).SketchArcs.AddByCenterStartEndPoint(tg.CreatePoint2d(-12, 0), tg.CreatePoint2d(2.72888, -6.25), tg.CreatePoint2d(2.7288, 6.25), True)
Call oSketch(2).GeometricConstraints.AddCoincident(oLine(4),oSkArc(2).CenterSketchPoint)
Call oSketch(2).GeometricConstraints.AddCoincident(oPrLine(3),oSkArc(2).CenterSketchPoint)
Call oSketch(2).GeometricConstraints.AddVerticalAlign(oSkArc(2).StartSketchPoint, oSkArc(2).EndSketchPoint)
Call oSketch(2).GeometricConstraints.AddHorizontalAlign(oSkArc(2).StartSketchPoint, oPoint(3))
oRDim(2) = oSketch(2).DimensionConstraints.AddRadius(oSkArc(2), tg.CreatePoint2d(-3.17, 1.7155))
oRDim(2).Parameter.Expression = "d5=160mm"
oSkArc(3) = oSketch(2).SketchArcs.AddByCenterStartEndPoint(tg.CreatePoint2d(-12, 0), tg.CreatePoint2d(3.8094, -6.25), tg.CreatePoint2d(3.8094, 6.25), True)
Call oSketch(2).GeometricConstraints.AddCoincident(oLine(4),oSkArc(3).CenterSketchPoint)
Call oSketch(2).GeometricConstraints.AddCoincident(oPrLine(3),oSkArc(3).CenterSketchPoint)
Call oSketch(2).GeometricConstraints.AddVerticalAlign(oSkArc(3).StartSketchPoint, oSkArc(3).EndSketchPoint)
Call oSketch(2).GeometricConstraints.AddHorizontalAlign(oSkArc(3).StartSketchPoint, oPoint(3))
oRDim(3) = oSketch(2).DimensionConstraints.AddRadius(oSkArc(3), tg.CreatePoint2d(-3.210, 5.323))
oRDim(3).Parameter.Expression = "d6=170mm"
Call oSketch(2).Solve
''Surface Revolve
oProfile(1) = oSketch(2).Profiles.AddForSurface(oSkArc(2))
Dim oRevolve(2) As RevolveFeature
oRevolve(1) = oPartDef.Features.RevolveFeatures.AddByAngle(oProfile(1),oLine(4),"d8 = 90deg",PartFeatureExtentDirectionEnum.kNegativeExtentDirection,PartFeatureOperationEnum.kSurfaceOperation)
oRevolve(1).Name = "Surface_Revolve_160"
''end First Surface
''Surface Revolve
oProfile(2) = oSketch(2).Profiles.AddForSurface(oSkArc(3))
oRevolve(2) = oPartDef.Features.RevolveFeatures.AddByAngle(oProfile(2),oLine(4),"d9 = 90deg",PartFeatureExtentDirectionEnum.kNegativeExtentDirection,PartFeatureOperationEnum.kSurfaceOperation)
oRevolve(2).Name = "Surface_Revolve_170"
''end Second Surface
'[Extrusion upto Surface160
Dim oSurf(2) As WorkSurface
Dim oSurfBody(2) As SurfaceBody
oSurf(1) = oRevolve(1).SurfaceBodies.Item(1).Parent
oSurf(1).Translucent = True
oSurf(1).Visible = False
oSurfBody(1) = oSurf(1).SurfaceBodies.Item(1)
oSurf(2) = oRevolve(2).SurfaceBodies.Item(1).Parent
oSurf(2).Translucent = True
oSurf(2).Visible = False
oSurfBody(2) = oSurf(2).SurfaceBodies.Item(1)
oProfile(3) = oSketch(1).Profiles.AddForSolid()
' Dim oExtrusion(10) As ExtrudeFeature
oExtrusion(1) = oPartDef.Features.ExtrudeFeatures.AddByToNextExtent(oProfile(3), PartFeatureExtentDirectionEnum.kPositiveExtentDirection,oSurfBody(1), PartFeatureOperationEnum.kNewBodyOperation)
oExtrusion(1).Name = "Extrusion upto Surface160"
oExtrusion(1).TaperAngle.Name = "d10"
'[....Offset Sketch
oSketch(3) = oPartDef.Sketches.Add(oPartDef.WorkPlanes.Item(2))
oSketch(3).Name = "Offset Sketch"
oPrLine(4) = oSketch(3).AddByProjectingEntity(oLine(1))
oPrLine(5) = oSketch(3).AddByProjectingEntity(oLine(2))
oPrLine(6) = oSketch(3).AddByProjectingEntity(oLine(3))
oPrjArc = oSketch(3).AddByProjectingEntity(oSkArc(1))
Dim oSkEntColl As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection()
oSkEntColl.Add(oPrLine(4))
oSkEntColl.Add(oPrLine(5))
oSkEntColl.Add(oPrjArc)
oSkEntColl.Add(oPrLine(6))
Dim oOffsetEnt As SketchEntitiesEnumerator
oOffsetEnt = oSketch(3).OffsetSketchEntitiesUsingDistance(oSkEntColl,2.5,False,False,True)
oOffsetEnt.Item(1).Construction = True
' Dim oLinex(0 To 3) As SketchLine
' For i = 0 To 3
' oSketchLines = oOffsetEnt.Item
' aoDrawCurves(i) = oDrawViewCurves.Item(1)
' Next
' For Each oLinex As SketchLine In oOffsetEnt
'If oLinex(1) Is oOffsetEnt.Item(1) Then
'End If
'Next
' Next
' Call oOffsetEnt(1) = oLine(7)
Dim oCamera As Camera
oCamera = ThisApplication.ActiveView.Camera
oCamera.ViewOrientationType = ViewOrientationTypeEnum.kLeftViewOrientation
oCamera.Apply()
iLogicVb.UpdateWhenDone = True' Dim oCamera7 As Camera
ElapsedTime = Now().Subtract(StartTime)
MessageBox.Show("Time Taken To Create Model Mania 2004: " & ElapsedTime.TotalSeconds & " Seconds", "CAD PROFESSOR")
ThisDoc.Save
Sub Main() Dim StartTime As DateTime Dim ElapsedTime As TimeSpan StartTime = Now ' Defining This Document Dim oPartDoc As PartDocument = ThisApplication.ActiveDocument 'Definining a Component Definition Dim oPartDef As PartComponentDefinition = oPartDoc.ComponentDefinition Dim oParams As Parameters oParams = oPartDef.Parameters Dim oUserParams As UserParameters oUserParams = oParams.UserParameters Dim assetLib As AssetLibrary = ThisApplication.AssetLibraries.Item("Autodesk Appearance Library") Dim oCircle(10) As SketchCircle Dim oLine(20) As SketchLine Dim oPrLine(20) As SketchLine Dim oPoint(10) As SketchPoint Dim oProjectionPoint(10) As SketchPoint Dim oCon(10) As CoincidentConstraint Dim oDim(10) As TwoPointDistanceDimConstraint Dim oOffsetDim(6) As OffsetDimConstraint Dim oAngDim(6) As TwoLineAngleDimConstraint Dim oProfile(6) As Profile Dim oExtrudeDef(0 To 6) As ExtrudeDefinition Dim oExtrusion(6) As ExtrudeFeature Dim oFillet(10) As FilletFeature Dim oSkArc(10) As SketchArc Dim oPrArc(10) As SketchArc Dim oArcDim(10) As ArcLengthDimConstraint Dim oAngleDim(10) As ThreePointAngleDimConstraint Dim oRDim(0 To 6) As RadiusDimConstraint Dim oTanDim(10) As TangentDistanceDimConstraint Dim oRs(3) As RenderStyle Dim oProximityPoint(10) As Point2d Dim oProximityPoints(10) As Point Dim ExtrudeFeatDistExtent(10) As DistanceExtent '[ Create's a Profile Sketch Dim oSketch(10) As PlanarSketch oSketch(1) = oPartDef.Sketches.Add(oPartDef.WorkPlanes.Item(2)) oSketch(1).Name = "Base Profile Sketch" 'Collecting Transient Geometry Dim tg As TransientGeometry tg = ThisApplication.TransientGeometry oRs(1) = oPartDoc.RenderStyles.Item("Default") oRs(2) = oPartDoc.RenderStyles.Item("Shellac") oRs(3) = oPartDoc.RenderStyles.Item("Red") oPartDoc.ActiveRenderStyle = oRs(2) oProjectionPoint(1) = oSketch(1).AddByProjectingEntity(oPartDef.WorkPoints.Item(1)) oLine(1) = oSketch(1).SketchLines.AddByTwoPoints(tg.CreatePoint2d(0, 6.25), tg.CreatePoint2d(0, - 6.25)) Call oSketch(1).GeometricConstraints.AddVertical(oLine(1)) oLine(2) = oSketch(1).SketchLines.AddByTwoPoints(oLine(1).EndSketchPoint, tg.CreatePoint2d(8.9325, -3.8565)) oLine(3) = oSketch(1).SketchLines.AddByTwoPoints(oLine(1).StartSketchPoint, tg.CreatePoint2d(8.9325, 3.8565)) oPrLine(1) = oSketch(1).AddByProjectingEntity(oPartDef.WorkAxes.Item(1)) oPrLine(1).Construction = True Call oSketch(1).GeometricConstraints.AddCoincident(oLine(1), oProjectionPoint(1)) oSkArc(1) = oSketch(1).SketchArcs.AddByCenterStartEndPoint(tg.CreatePoint2d(2.5, 0), oLine(2).EndSketchPoint,oLine(3).EndSketchPoint,True) Call oSketch(1).GeometricConstraints.AddVerticalAlign(oSkArc(1).StartSketchPoint, oSkArc(1).EndSketchPoint) Call oSketch(1).GeometricConstraints.AddCoincident(oSkArc(1).CenterSketchPoint,oPrLine(1)) Call oSketch(1).GeometricConstraints.AddSymmetry(oLine(2),oLine(3),oPrLine(1)) oDim(1) = oSketch(1).DimensionConstraints.AddTwoPointDistance(oLine(1).StartSketchPoint,oLine(1).EndSketchPoint,DimensionOrientationEnum.kVerticalDim,tg.CreatePoint2d(-2.5,0)) oDim(1).Parameter.Expression = "d0=125" oRDim(1) = oSketch(1).DimensionConstraints.AddRadius(oSkArc(1), tg.CreatePoint2d(7.5,- 1.7)) oRDim(1).Parameter.Expression = "d1=75mm" oProximityPoint(1) = tg.CreatePoint2d(10.0, 0) oProximityPoint(2) = tg.CreatePoint2d(0, 0) oTanDim(1) = oSketch(1).DimensionConstraints.AddTangentDistance(oSkArc(1), oLine(1),oProximityPoint(1), oProximityPoint(2), tg.CreatePoint2d(5.00, -8.0), False) oTanDim(1).Parameter.Expression= "d2=100" oPoint(1) =oSketch(1).SketchPoints.Add(tg.CreatePoint2d(8.9325, -6.25)) Call oSketch(1).GeometricConstraints.AddHorizontalAlign(oLine(1).EndSketchPoint, oPoint(1)) Call oSketch(1).GeometricConstraints.AddVerticalAlign(oLine(2).EndSketchPoint, oPoint(1)) oAngleDim(1) = oSketch(1).DimensionConstraints.AddThreePointAngle(oPoint(1),oLine(1).EndSketchPoint,oLine(2).EndSketchPoint,tg.CreatePoint2d(10.8,-4.7)) oAngleDim(1).Parameter.Expression = "d3=15" Call oSketch(1).Solve '] '[ Create's a Revolve Sketch oSketch(2) = oPartDef.Sketches.Add(oPartDef.WorkPlanes.Item(1)) oSketch(2).Name = "Revolve Surface Sketch" oProjectionPoint(2) = oSketch(2).AddByProjectingEntity(oPartDef.WorkPoints.Item(1)) oLine(4) = oSketch(2).SketchLines.AddByTwoPoints(tg.CreatePoint2d(-12.0, -6.25), tg.CreatePoint2d(-12.0, 6.25)) Call oSketch(2).GeometricConstraints.AddVertical(oLine(4)) oLine(4).Construction = True oLine(4).Centerline = True oPoint(2) = oSketch(2).AddByProjectingEntity(oLine(1).StartSketchPoint) oPoint(3) =oSketch(2).AddByProjectingEntity(oLine(1).EndSketchPoint) Call oSketch(2).GeometricConstraints.AddHorizontalAlign(oLine(4).StartSketchPoint,oPoint(2)) Call oSketch(2).GeometricConstraints.AddHorizontalAlign(oLine(4).EndSketchPoint,oPoint(3)) oPrLine(2) = oSketch(2).AddByProjectingEntity(oPartDef.WorkAxes.Item(3)) oPrLine(2).Construction = True oPrLine(3) = oSketch(2).AddByProjectingEntity(oPartDef.WorkAxes.Item(2)) oPrLine(3).Construction = True oDim(2) = oSketch(1).DimensionConstraints.AddTwoPointDistance(oLine(4).StartSketchPoint,oPoint(2),DimensionOrientationEnum.kHorizontalDim,tg.CreatePoint2d(-7.4,11.5)) oDim(2).Parameter.Expression = "d4=120" oSkArc(2) = oSketch(2).SketchArcs.AddByCenterStartEndPoint(tg.CreatePoint2d(-12, 0), tg.CreatePoint2d(2.72888, -6.25), tg.CreatePoint2d(2.7288, 6.25), True) Call oSketch(2).GeometricConstraints.AddCoincident(oLine(4),oSkArc(2).CenterSketchPoint) Call oSketch(2).GeometricConstraints.AddCoincident(oPrLine(3),oSkArc(2).CenterSketchPoint) Call oSketch(2).GeometricConstraints.AddVerticalAlign(oSkArc(2).StartSketchPoint, oSkArc(2).EndSketchPoint) Call oSketch(2).GeometricConstraints.AddHorizontalAlign(oSkArc(2).StartSketchPoint, oPoint(3)) oRDim(2) = oSketch(2).DimensionConstraints.AddRadius(oSkArc(2), tg.CreatePoint2d(-3.17, 1.7155)) oRDim(2).Parameter.Expression = "d5=160mm" oSkArc(3) = oSketch(2).SketchArcs.AddByCenterStartEndPoint(tg.CreatePoint2d(-12, 0), tg.CreatePoint2d(3.8094, -6.25), tg.CreatePoint2d(3.8094, 6.25), True) Call oSketch(2).GeometricConstraints.AddCoincident(oLine(4),oSkArc(3).CenterSketchPoint) Call oSketch(2).GeometricConstraints.AddCoincident(oPrLine(3),oSkArc(3).CenterSketchPoint) Call oSketch(2).GeometricConstraints.AddVerticalAlign(oSkArc(3).StartSketchPoint, oSkArc(3).EndSketchPoint) Call oSketch(2).GeometricConstraints.AddHorizontalAlign(oSkArc(3).StartSketchPoint, oPoint(3)) oRDim(3) = oSketch(2).DimensionConstraints.AddRadius(oSkArc(3), tg.CreatePoint2d(-3.210, 5.323)) oRDim(3).Parameter.Expression = "d6=170mm" Call oSketch(2).Solve ''Surface Revolve oProfile(1) = oSketch(2).Profiles.AddForSurface(oSkArc(2)) Dim oRevolve(2) As RevolveFeature oRevolve(1) = oPartDef.Features.RevolveFeatures.AddByAngle(oProfile(1),oLine(4),"d8 = 90deg",PartFeatureExtentDirectionEnum.kNegativeExtentDirection,PartFeatureOperationEnum.kSurfaceOperation) oRevolve(1).Name = "Surface_Revolve_160" ''end First Surface ''Surface Revolve oProfile(2) = oSketch(2).Profiles.AddForSurface(oSkArc(3)) oRevolve(2) = oPartDef.Features.RevolveFeatures.AddByAngle(oProfile(2),oLine(4),"d9 = 90deg",PartFeatureExtentDirectionEnum.kNegativeExtentDirection,PartFeatureOperationEnum.kSurfaceOperation) oRevolve(2).Name = "Surface_Revolve_170" ''end Second Surface '] '[Extrusion upto Surface160 Dim oSurf(2) As WorkSurface Dim oSurfBody(2) As SurfaceBody oSurf(1) = oRevolve(1).SurfaceBodies.Item(1).Parent oSurf(1).Translucent = True oSurf(1).Visible = False oSurfBody(1) = oSurf(1).SurfaceBodies.Item(1) oSurf(2) = oRevolve(2).SurfaceBodies.Item(1).Parent oSurf(2).Translucent = True oSurf(2).Visible = False oSurfBody(2) = oSurf(2).SurfaceBodies.Item(1) oProfile(3) = oSketch(1).Profiles.AddForSolid() ' Dim oExtrusion(10) As ExtrudeFeature oExtrusion(1) = oPartDef.Features.ExtrudeFeatures.AddByToNextExtent(oProfile(3), PartFeatureExtentDirectionEnum.kPositiveExtentDirection,oSurfBody(1), PartFeatureOperationEnum.kNewBodyOperation) oExtrusion(1).Name = "Extrusion upto Surface160" oExtrusion(1).TaperAngle.Name = "d10" '] '[....Offset Sketch oSketch(3) = oPartDef.Sketches.Add(oPartDef.WorkPlanes.Item(2)) oSketch(3).Name = "Offset Sketch" oPrLine(4) = oSketch(3).AddByProjectingEntity(oLine(1)) oPrLine(5) = oSketch(3).AddByProjectingEntity(oLine(2)) oPrLine(6) = oSketch(3).AddByProjectingEntity(oLine(3)) oPrjArc = oSketch(3).AddByProjectingEntity(oSkArc(1)) Dim oSkEntColl As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection() oSkEntColl.Add(oPrLine(4)) oSkEntColl.Add(oPrLine(5)) oSkEntColl.Add(oPrjArc) oSkEntColl.Add(oPrLine(6)) Dim oOffsetEnt As SketchEntitiesEnumerator oOffsetEnt = oSketch(3).OffsetSketchEntitiesUsingDistance(oSkEntColl,2.5,False,False,True) oOffsetEnt.Item(1).Construction = True ' Dim oLinex(0 To 3) As SketchLine ' For i = 0 To 3 ' oSketchLines = oOffsetEnt.Item ' aoDrawCurves(i) = oDrawViewCurves.Item(1) ' Next ' For Each oLinex As SketchLine In oOffsetEnt '' 'If oLinex(1) Is oOffsetEnt.Item(1) Then 'End If 'Next ' Next ' Call oOffsetEnt(1) = oLine(7) '] Dim oCamera As Camera oCamera = ThisApplication.ActiveView.Camera oCamera.ViewOrientationType = ViewOrientationTypeEnum.kLeftViewOrientation oCamera.Apply() iLogicVb.UpdateWhenDone = True' Dim oCamera7 As Camera oPartDoc.ActiveRenderStyle = oRs(2) ElapsedTime = Now().Subtract(StartTime) MessageBox.Show("Time Taken To Create Model Mania 2004: " & ElapsedTime.TotalSeconds & " Seconds", "CAD PROFESSOR") ThisDoc.Save
Please mark this response as Problem Solved if it answers your question.
Ravi Kumar MB,
HP Z220 SFF Workstation
Autodesk Inventor Certified professional 2016
Email: ravikmb5@gmail.com
