A solution Annoying Print Setup in Inventor? It is working for us!
binuvarkey
Message 1 of 1
binuvarkey
Attached file contains a vba form and 2 modules, we use here to print from inventor drawings.
(forgive me for not following any programming standards methods).
Thought this would be of use to many here.
I have not modified the code to suit generic use. It is setup to use our department printer as the default printer (It will list all printers installed each time and you can select the correct one).
Anyone cleans/modifies the code and convert to an addin or to make it work with Ribbon interface, please post back here. Currently I have the macros on a tool bar.
Thank you
Binu
Replies (0)
