64Bit Addin failure
64Bit Addin failure
64Bit Addin failure
I'm new to Inventor as well as .Net.
I created an add-in that starts a shell and fires an outside .exe that integrates with Inventor. The 32bit version works fine.
We got some new 64bit workstations so I have to recreate the addins in .Net to call the 32bit application. I used the template provided for .Net but I am having troubles. The Add-In displays in Inventor but won't stay loaded. I can"t debug in VS2010 Express like I could in VB6 because there is only code and no functions.
Any help/ideas? I have attached my project file.
Thanks in advanced.
OK, well after I unregistered older attempts, I re-registered the new add-in and it loads and shows the proper panel/buttons, but without the icons. Also, no action when clicked.
I appreciate any input!
Solved.
I had cut and pasted my OnExecute events from  a VB6 add-in, and they were in the wrong region, so clicking the buttons did nothing.
As for the icons, I ended up using:
Dim InventorAddin_FNIcon As stdole.IPictureDisp
InventorAddin_FNIcon = Microsoft.VisualBasic.Compatibility.VB6.Support.IconToIPicture(My.Resources.FN)
Everything works perfectly!
