2019 ilogic ClearanceInfo error
Inventor Professional 2019 64 bit on Windows 10
While trying to access the ClearanceInfo method with ilogic using the following code to extract the fastener size string, Inventor 2019 crashes. Any attempt to access the FitType, Size, Standard, Type, etc. causes Inventor to close immediately.
SyntaxEditor Code Snippet
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
Dim oDef As PartComponentDefinition
oDef = oDoc.ComponentDefinition
Dim oHole As HoleFeature
Dim oHoles As HoleFeatures
oHoles = oDef.Features.HoleFeatures
If oHoles.Count > 0 Then
	For Each oHole In oHoles
		If oHole.IsClearanceHole = True Then
			Dim oFastener As String
			oFastener = oHole.ClearanceInfo.FastenerSize
	Next
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
There is already a change request(INVGEN - 13154) with engineering team. I will update you on further progress.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
I will await the update, thanks!
@chandra.shekar.g
Is there a way for me to check on the status of this change request? I would like to stay informed when it is released as well.
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous ,
Code has been modified to address this issue in the upcoming Inventor release.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
