Report Generator
Report Generator
It could be useful to add the possibilty to generate a report even for Buckling analysis or for Non-linear analysis.
It is a note coming from a client.
Thank you,
Luca
20 Comments
mitch.muncy
Status changed to: Accepted
There's a lot that could be improved with In-CAD reports.
Reporting is an essential part of tracking Simulation result generation and could be a real asset to users if done well.
Matthew
matthewweake
We have been running some workshops for prospects over this last week and this issue has been raised by several attendees in every class.
Happy to discuss in detail.
Regards
Matthew Weake
CADPRO Systems Ltd
New Zealand
benalain13
making the report for any classical analysis : static linear and non linear ; vibration analysis
thanks
julio_galindo
Unfortunately without a proper report method for non linear analysis, as all others have mentioned, Incad Nastran really loose a lot of utility.
israel.cidad
there is no "Generate report" able for "Normal modes", in Nastran In-CAD 2018.
Regards.
To start with, would it not be possible to use the same format as for the linear analysis?
You could then just show the final results of the analysis.his would at least be usefull for what I am doing at the moment.
Nastran in-CAD has a lot of room to be improved.
RichardLee3904
Not having some type of report feature makes analysis work VERY inefficient
bmazaheri9ZTPW
Quite disappointing not having this feature for Shock/Response Spectrum analysis.
Has there been any evolution of this subject since 2015? Has Autodesk provided ways to customize Nastran In Cad reports or creating of new report templates? 4 years past and nothing?
4.5 years now and still nothing evident. Can you provide an update on any progress that has been made on generating FEA reports for non-linear analyses please?
jcoveyou
I have been using other FEA programs for a few years and just recently started to use the Nastran Incad tool. After using the Inventor tool for a while, it has been nice to see the capabilities and enhanced functionality of the Nastran tool. After spending a significant amount of time over the last few weeks learning to use the tool, I attempted to write a report for a fatigue study that I am working on. It was very disappointing to learn now that there is no ability to generate any form of a report of the results as there is for the linear static analysis. The lack of this ability renders the tool almost useless in the ability to be able to convey simulation results to others inside your organization nor customers that have interest in them. Based on what I am seeing in earlier comments in this thread, there are many other analysis study types that also do not have report generating abilities. It is unfortunate that a tool with this much capability and potential lacks such an important feature to be able to complete a study effort. The report generating ability should be a priority for all study types in the Nastran Incad tool.
PeterHintze.2195
It would be nice to have an option of customization of the default report (from a to z) as well as to chose the size and the perspective of the pictures inserted? With the options given, there is not much possible to change.
Moreover, the translation from English to German leaves much to be desired. So I'd like to avoid making the same corrections thousand times over! If somebody knows how to do it, I'll appreciate it very much!
scole
Community Visitor
Not having the ability to produce reports for different analyses feels similar to a word processing program that lacks a print button.  It is truly unfortunate, because otherwise this is a great tool.
diego.rusnighi
Is not possibile to produce a report for  "Thermal analysis" (linear e not linear), in Nastran 2022.
"Generate report" is not activable.
 Reporting for all the analysis is an essential part of tracking Simulation
Regards
Ledford
Would also like to see this issue addressed for random response simulations.
gbosua
Community Visitor
When will this package be able to generate a report file for Fatigue Analysis. My customers do not accept a manual self generated report with Windows snip-out function and Report compiled in Word. Can I get direct communication with someone in this team to speak to about this Fatigue Analysis funktion, I don't think it computes correctly.
Plus I have several other question I would like to get clarity on.
HegdeWJ9F6
This thread is ON from 2015. In these 8 years has Autodesk still not sorted out "Generate Report" for non linear analysis?? or for that matter any analysis other than linear static. Really sad!!
hakan.falt
Community Visitor
Hello
Our customers want to see a report on how the calculation is set up. This requirement has increased over the years.
