post processing for connecotor and beam
Hi
We would like to be able to have force calculated for connector and beams, by directly select the connector (or beam) in the tree and then right Clic to have all the forces (and moment) for the selected entity.
In the same aspect of what we have for the Sum of SPC...
Actually the post processcing for such 1D entity is very tricky..
thanks
1 Comment
imajar
I may not understand this request - I almost always have multiple beams/connectors assigned to each property, so distinguishing which one is which in the report would be as much work as probing them manually. . . but maybe I'm not understanding?
I assume you know that you can probe beams and connectors to get the forces?  (by turning on forces in the analysis output? for beams the results are available in the beam diagrams and for connectors the forces are available in other)
Technology Administrators
