Plot Templates Improvements
Currently plot templates are not very useful. The following are shortfalls. You cannot specify the result type in the plot template. You can check and specify a range for the template but it is not saved. Templates must be created for each nastran in-cad file that is made.
I would suggest the following improvements.
  1. Make it so that the result type is specified in the template. I want one template to be for stress, and to display von-Mises solid stresses. I want another template to be for stress, and to display von-Mises shell stresses, etc.
  2. Make the range values stay when the template is applied to a subcase result set. If I have the range box checked and a minimum value of 0 psi set and a maximum value of 16500 psi set in the template, I want it to apply to each subcase I put the template in.
  3. Make it so that the results template files can be saved to an external file where they can be recalled easily for use in any nastran in-cad file. Maybe this would be a user defaults file.
  4. Also it would be nice if selected templates are automatically applied to each result set.
These changes would save a lot of time in the post processing environment.
1 Comment
mitch.muncy
