max results per part
Hi
It would be nice to have a max results list for each part of an assembly
we had this in the past in SImech and it helps a lot
actually the results contours options is not helpful..and tricky
1 Comment
Dr_Nastran
There are several ways to do this now but you will need to add lines to the Case Control before you run the model.
1) Using RESULTLIMITS
https://help.autodesk.com/view/NINCAD/2024/ENU/?guid=GUID-BD4C4105-A80E-4732-ADC7-04686ED95DFB
2) Using VOLUME
https://help.autodesk.com/view/NINCAD/2024/ENU/?guid=GUID-5A9DA57B-3DA7-4568-8E49-9A8068164014
For each of these you would need to generate a SET with the elements in the property using
https://help.autodesk.com/view/NINCAD/2024/ENU/?guid=GUID-66041FB1-0078-4852-A2FC-26266A7DC198
Its sounds complicated but there are a lot of defaults so it really is not that bad...
SETGENERATE, 1, ELEM, , PID, 105
generates a set with all elements in property 105.  Then you can use that SET in the VOLUME as
VOLUME 1, SET 1, SYSTEM BASIC
Which will generate a VOLUME with just property 105 and in the .LOG file you will have the max/min results for that property.
