Show only
Search instead for
I would like to be able to hide the (white) Edges of the Shell elements shown in the graphics window. Maybe even better, hide the solids that have been selected for Shell elements.
In the Default settings, Display Options, turn off Free Edge to not show the white lines when reviewing the results for models using shell elements.
Regarding hiding solids, a workaround for now is to define all of your shell elements based on the solids, switch to the modeling environment and turn the visibility of the solid bodies off. If you leave the solids visible, they should not be showing up in the results as long as you have not given them a physical property definition.
