Currently, I have a quite large model with 11 different load cases.
To be able to analyze and compare the results of all load cases, it would be nice to be able to have each result category (for example vonMises stress, displacement) to look the same, but different from the pre-defined template.
For example, I would like to have the vonMises results with the same min/max values, 5% displacement, no mesh shown).
With 11 load cases, I have to change that in each individual load case result. Add to that the same for displacement results: 22 individual adaptions.
This is really cumbersome ind time consuming.
It would be nice to be able to define global results setting and that to be applied to all load case results.
