Duplicate Connections
When doing multiple bolted conections you can click on the 'Create Duplicate' button on the bottom left corner of the Connector wizard.  This keeps the same setting so you can quickly continue with a bolt pattern.  However, it does not clear the 'Connector Element'.  You have to manual clear these windows in order to select the next bolt location.
I suggest that when you click 'Create Duplicate' the 'Connector Element' windows should be cleared.
The benifit would be reducing mouse clicks which would reduce developement time.
Cheers,
David
1 Comment
AndrewSears
