Alert output when element order is changed in InventorNastran thermal stress coupled analysis
In Inventor Nastran's thermal stress coupled analysis, I would like an error (or alert) message to be output if the element order used in the heat conduction analysis is different from the element order used in the stress analysis. Currently, even if the element orders are different (for example, if the element order used in the stress analysis is accidentally changed), the calculation is carried out without any message, which can lead to incorrect results being taken for granted.
*This issue has been reported to Autodesk Japan Support (case_No. 25488122).
