Dear All
is there any guidance please on how to proceed when simulating the vibration load on a plastic pin pushed into a metal housing. where would the desired output be if the plastic part "shakes off" from the case when gravity and vibrations are applied?
Thank you for your help
Hi @sklar
This sounds like a tricky simulation. Here are some things you need to figure out.
Let's think of some simple examples.
Assuming the theory will handle the arrangement, now you can determine if the vibration analysis provides the results that are needed. For example, the analysis types that use a modal analysis (shock/response spectrum, modal frequency response, random response) may only provide a "positive" result. See this article for an example: Reaction forces are unexpected in a Shock/Response Spectrum analysis in Nastran. If you need the total contact force between the pin and hole, is there any limitation on the sign of the contact force output by the vibration analysis? You may want to do a test model or two to confirm the results that you need are available.
Good luck.
John
