Hi @smirnov.da
Do not use "Continuous Meshing" with solid parts.
Continuous Meshing only matches the mesh at some nodes around the perimeter of the contact when using solids. (By matching, I mean the same node number is used on both parts.) If a node is matched, there is no contact at that node. Since there is no contact, there is no contact force.
In other words, your two parts were connected by a matched mesh at some locations and by contact at other locations. Some of the load was transmitted through the matched mesh, and some of the load was transmitted through the bonded contact. Therefore, the summation of the contact force was only a portion of the total load transmitted.
When not using continuous meshing, the entire load is transmitted through the contact, and the sum of the contact forces is as expected. (These results are for assembly2.iam.)
Result: |
[202] T1 CONTACT FORCE |
[203] T2 CONTACT FORCE |
[204] T3 CONTACT FORCE |
| Subcase |
Node |
| [1] SUBCASE 1 |
1 |
-0.36 |
-49.61 |
0.22 |
| [1] SUBCASE 1 |
2 |
0.19 |
-49.36 |
-0.07 |
| [1] SUBCASE 1 |
46 |
0.11 |
-51.13 |
0.20 |
| [1] SUBCASE 1 |
47 |
-0.07 |
-33.10 |
-0.22 |
| [1] SUBCASE 1 |
48 |
0.02 |
-27.00 |
-0.05 |
| [1] SUBCASE 1 |
49 |
0.24 |
-39.15 |
-0.12 |
| [1] SUBCASE 1 |
61 |
0.22 |
-51.23 |
-0.10 |
| [1] SUBCASE 1 |
62 |
0.05 |
-33.66 |
0.04 |
| [1] SUBCASE 1 |
63 |
0.09 |
-27.67 |
0.03 |
| [1] SUBCASE 1 |
64 |
-0.54 |
-39.47 |
-0.10 |
| [1] SUBCASE 1 |
100 |
-0.32 |
-12.78 |
0.21 |
| [1] SUBCASE 1 |
101 |
0.15 |
-35.79 |
0.00 |
| [1] SUBCASE 1 |
103 |
0.04 |
-36.54 |
-0.06 |
| [1] SUBCASE 1 |
104 |
0.17 |
-13.42 |
0.04 |
| [1] SUBCASE 1 |
Sum |
0.00 |
-499.91 |
0.00 |
Let us know if you have any questions.
John Holtz, P.E. Global Product Support
Autodesk, Inc. If not provided, indicate the version of Inventor Nastran you are using.If the issue is related to a model, attach the model! See What files to provide when the model is needed.
