Inventor Nastran Forum
Welcome to Autodesk’sInventor Nastran Forums. Share your knowledge, ask questions, and explore popular Inventor Nastran topics.
Use Continuous Meshing with caution
3 REPLIES 3
John_Holtz
2938 Views, 3 Replies
The option "Continuous meshing" on the mesh settings is intended to be used with shell elements. It's purpose is to connect the edges of one shell to the edge of the adjacent shell. (In other words, the mesh matches between faces. The loads are transferred directly from element to element without the need to use contact to bond the faces together.)
There are issues with the continuous meshing option when anything is applied to an edge of a shell. This includes loads, constraints, rigid connectors, bolt connectors, contact, and so on. Depending on the version of Inventor Nastran you use, the item applied to the edge can be applied to additional edges of the model during the analysis, or it can be applied to only some (or none) of the nodes on the selected edges. For example, extra load can be applied to the model, or some of the load may be missing.
If you have used continuous meshing, check the results carefully to look for potential problems with the results.
Here are some alternatives to using continuous meshing:
  • If the model is a single part surface model that has only one surface body, you do not need to use continuous meshing. The single body meshes as one continuous piece (regardless of how many faces the single body has).
  • If the model is a single part surface that has multiple surface bodies, use the "3D Model > Surface > Stitch" command to join the surfaces into one surface body. (I am not sure what this does to any split faces. Those may need to be re-done after stitching the surfaces.)
  • If the model cannot be stitched, use "Contacts > Solver" . Set the Contact Type to offset bonded. (Offset bonded is used to create a moment connection which is generally what is used for a shell-to-shell connection. Bonded contact only transmits forces, not forces and moment.) The maximum activation distance should be slightly larger than the gap between the edges but no larger than half the mesh size.
Here are some articles on the Autodesk Knowledge Network (knowledge.autodesk.com) that are related to these items:
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
3 REPLIES 3
g.ceruti
in reply to: John_Holtz
hi @John_Holtz
can you detail which Inventor Nastran versions are involved with this issue?
Roelof.Feijen
Another way to create a successful mesh if stitching cannot be used and you don't want to use the Solver Contact.
Note that split is essential in this case (video) and you need to delete all the features after using the Copy Object command. Otherwise you will end up with a double layer of faces.
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
arashS6VPN
Hello
I have tried it but unfortunately it did not work.
