Troubleshooting Grid Point Singularity E5010
I have a model containing line, shells, and solids. During the solution process of each subcase, I am getting an E5010 warning. There is a slight discrepancy in the deflected shape (applying a test symmetric load on a symmetric model, and getting non-symmetric deflection). I'd like to pinpoint the grid that is causing the issue so I can further review and either dismiss the warning, or make a correction in the model. The on-line help suggests to "Check the Grid Point Singularity Table in the Model Results Output File for degrees of freedom that should not be auto-constrained".
Where/How do I review the "Model Results Output File"? A detailed step-by-step to locate the exact grid/element that is causing the warning would be very greatly appreciated. Thank you!!
