Cannot select points as constraints
Hello all,
I am analyzing displacement in pipes of 50 mm dia towards gravity.
For  some reason I am not able to select my vertice at the ground as my fixed constraint.
Its a bit urgent
Kindly help.
Thank you for your time.
Arya
shigeaki.k
Hello @Anonymous ,
could you elaborate further on what you are trying to do? I was able to select the points at the end of the lines and at the intersection.
Shigeaki K.
Shigeaki K.
Technical Support Specialist
サポートとラーニング | Support & Learning
