Inventor Nastran Forum
Welcome to Autodesk’sInventor Nastran Forums. Share your knowledge, ask questions, and explore popular Inventor Nastran topics.
Thin box analysis
4 REPLIES 4
Henrik_Lo
292 Views, 4 Replies
Thin box analysis
Hi
I need some help making this analysis realistic
I have this box mounted to a wall with two ø8mm screws.
A load inside for 100kg.
How to make constrain right, and etc.
It is 1mm material, mild steel.
Can this box take 100 kg.
Regards
Henrik
4 REPLIES 4
John_Holtz
in reply to: Henrik_Lo
Hi @Henrik_Lo
You said that the box is mounted to the wall. Should you add a constraint at the bottom of the box and acting in the Y direction to stop the box from passing into the wall?
Here are some other changes you should make:
  • Delete the Solid idealization. The model should only have the shell idealization and only have shell elements in the mesh.
  • 100 kg does not produce a load of 100 N (unless you are designing this for Pluto at 0.07G). At 1G, the load should be 980 N.
John Holtz, P.E.
Global Product Support
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
Henrik_Lo
in reply to: John_Holtz
Hi John
Thangs for replying
How about this then
I am not sure regarding the mesh elements how to change them to shell
Regards
Henrik
John_Holtz
Hi @Henrik_Lo
You wrote "I am not sure regarding the mesh elements how to change them to shell".
You do not need to change anything to shell. The model already is creating shell elements because there is a shell idealization (and shell results). The problem is there is also a solid idealization which is creating solid elements. My suggestion is to delete the solid idealization and remesh the model. There will be no solid elements when there is no solid idealization.
John Holtz, P.E.
Henrik_Lo
Hi John
I will tray to delete all the solid idealization, and see what is coming out then.
Regards
Henrik
Technology Administrators
