I'm looking for some assistance on where I'm going wrong setting up these analysis.
I'm analyzing a piping system that is subject to high temperature load from the material (1400F). The system is bolted onto the outlet of feeder.
I set-up a nonlinear stead state heat transfer analysis and applied an initial temperature of 70F, a temperature load of 1400 to the inside of the piping and a convection load to the outside components of the system (ambient temp 70, convection coefficient 1.6985e-5 btu/(s*in^2*F).
I load that temp output into a linear static analysis and also apply gravity to the simulation to see the combined stresses that will be seen throughout the model. But I get really high stress results and the stress locations are spotted throughout the chamber, piping and slide gates.
My question is am I setting this up correctly? Or is the nonlinear analysis not necessary? (I did a linear steady state as well with similar results)
Not applying the temperature output gives a max stress of around 52000 psi. With the temperature output from the nonlinear analysis its 712724 psi.
