Stabilization / soft springs - Nastran in CAD
algpi
Message 1 of 11
algpi
Dears,
Big request for a help in such a situation:
In attachments it’s a shaft, which I would like to load as shown "Shaft load.jpg":
- The bearing loads are balance,
- it’s single part without any constraints;
I can't run the analysis, because I've got receiving communicate "Nastran comunicate.jpg":
How I should to constrain / ground it / add stabilizing „soft” springs etc. to this model?
PS
In Inventor Stress Analysis module I can add such a „soft” springs to stabilize the model, and this is called "detect and Eliminate Rigid Body Modes".
Results form Inventor with marked above option are shown in "Results form Inventor stress module.jpg".
Is in Nastran in CAD such a possibility / function?
Thank You in advance for Your help.
Accepted solutions (3)
Replies (10)
Message 2 of 11
David_Kind
@algpi, I haven't found a "detect and eliminate rigid body modes" equivalent featured in NIC. Consider using the 3-2-1 method described here: http://www.eng-tips.com/viewthread.cfm?qid=176220 .
Message 3 of 11
algpi
@Anonymous
Many thanks for this method. I stud it and I understand, but it's quite dificult to use it to my shaft.
I tryed to fix points in plane of symetry in the way as it's described in this method, but result are not proper.
Probably it's becouse I've got no expirience in such an approach (method 3-2-1).
I attached my unsuccessful probe.
Could You help me with it?
Message 4 of 11
David_Kind
Can you supply the .ipt file?
Message 5 of 11
David_Kind
You could also split it once more in the XY plane and apply a second symmetrical constraint (in that plane). I think that'll fully constrain your model and solve it properly.
Message 6 of 11
algpi
In attachment the .ipt file.
Message 7 of 11
David_Kind
I made a couple changes and got the study to converge in a manner that's expected:
1. I split the model twice across planes of symmetry that are perpendicular to the load
2. I applied symmetrical constraints
3. I removed the bearing load at the end; and replaced it with a fixed constraint. Applying two opposing load didn't convergence. I suspect rounding error would never really sum up to zero. I'm not certain if this is strickly for bearing loads.
Message 8 of 11
algpi
Thank You for Your help
Best regards
Message 9 of 11
algpi
Dear David,
I found honestly what I was looking for:
https://forums.autodesk.com/t5/nastran-in-cad-forum/spring-stiffness/m-p/7221191
Message 10 of 11
algpi
Dear David,
Perfect for nonlinear, fatigue, etc.
Message 11 of 11
algpi
Dear David,
Regarding my question form PS:
"PS
Is in Nastran in CAD such a possibility / function?"
I've found such a function in Nastran parameters called "INERTIALRELIEF".
When You select "Auto" then software will find and eliminate rigid body modes.
Obviously it's working only in Linear Static Analysis when applied loads are in balance.
Best Regards
