Inventor Nastran Forum
Welcome to Autodesk’sInventor Nastran Forums. Share your knowledge, ask questions, and explore popular Inventor Nastran topics.
SPC graphic values visible
3 REPLIES 3
CCarreiras
476 Views, 3 Replies
HI!
How can i get visible the SPC values like the image below?
CCarreiras
3 REPLIES 3
John_Holtz
in reply to: CCarreiras
Hi Carlos,
You can get the reaction forces by right-clickling on a constraint in the model tree and choosing "SPC Summation". The values are shown in the dialog.
Once the dialog is visible, you can select different constraints or geometry to see the results at other locations.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
CCarreiras
in reply to: John_Holtz
HI!
Thank you.
I took  the above image from the nastran tutorial, and the question is: its  possible to get the values graphically in the model in Nastran software (as it show in the above picture) , or it's just an image for the tutorial.
My question is not how to get the values in the spc chart, but if it is possible to have the values as the image shows.
Thank you very much.
CCarreiras
John_Holtz
Hi Carlos,
That is an image that someone created for the tutorial. It is not possible for In-CAD to create an image of the results like that.
John Holtz, P.E.
Autodesk, Inc.
