- Mute
- Permalink
- Report
Hello all,
I am attempting to analyze a snap fit in Nastran and running into some issues. I've Simplified the problem to a near 2D representation of the system.
For now I am modeling this with the Autodesk Material Nylon with linear material models.
I have separation contacts between 3 parts, one moving part driven by an enforced motion load. The separation contacts are symmetric and manually set. In the nonlinear static version of the set up I have the stiffness factor as 1, 0 friction, 0 penetration surface offset and max activation distance checked by nothing in the field. No advanced settings set. The same contacts are used in the Explicit version.
The enforced motion is in one direction but relatively high (17mm).
In the nonlinear set up options I have it set for 100 iterations. After much adjustment I have finally gotten in to solve to the point right before the snap through. However, I have yet to have it solve past that point. I keep running into the error ER1004. Which is basically non-convergence.
I decided to try the Explicit solver as it should be better at this style of motion. I however, have not had any success in the separation contacts working correctly as I always have the moving body penetrate the stationary ones.
Any advice would be greatly appreciated.
Files attached.
Best,
Grant Chapman
