We are currently migrating data within this board to improve the community. During this process, posting, replying, editing and other features are temporarily disabled. We sincerely apologize for any inconvenience caused and appreciate your understanding. Thank you for your patience and support.
Sling Tension - lifting analysis
johnster100
Message 1 of 11
johnster100
I've currently running a lifting analysis on a large steel structure. The model has 4 lifting eyes and these are linked to the crane hook point using rigid connectors (all DoF free except the vertical direction).
The model creates displacements which look realistic but I would like to check the tension in slings to see that it matches with those which I have calculated.
Is there a way to extract this value from the model or the Nastran output file?
I've attached a simple model which shows the model setup:
thanks,
John
Replies (10)
Message 2 of 11
John_Holtz
Autodesk Support
Autodesk Support
Hi John ( @johnster100 )
I think the force in the rigid connectors is not available.
Fortunately, you should not be using a rigid connector anyway, so the proper way to do it will provide the force in the sling. See this article: How to perform analysis of lifting frame in Nastran. You will then be able to look at the force or stress result in the rod elements. (You may need to activate the Force output by editing the analysis type, but I do not remember all of the details.)
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
Message 3 of 11
johnster100
Thanks for that John.
What is the problem with using the rigid connector? I find the rods annoying to use as these elongate themselves. This  makes measuring the actual displacements in the structure itself difficult, i.e. you have to subtract the rod elongation.
thanks,
John
Message 4 of 11
John_Holtz
Autodesk Support
Autodesk Support
The main problem with the rigid connector is they do not provide a force which is one result that you wanted. You can increase the area of the rod elements to simulate a "rigid" wire.
The other problem with the rigid connector is that it prevents the lift points from moving relative to each other. The rod elements have a tension which puts the frame into compression, and therefore the lift eyes can deform toward each other. This is more realistic than the rigid connectors.
John Holtz, P.E.
Autodesk, Inc.
Message 5 of 11
wCorreiaHBYAR
Increasing the area of the rod connectors shifts the system COG and introduces additional unwanted moments which cause large displacements. do we have a solution to this?
Message 6 of 11
John_Holtz
Autodesk Support
Autodesk Support
The stiffness of the rod is controlled by two things: the cross-sectional area, and the modulus of elasticity. If you are including gravity and that is changing the CG, then don't change the area. Change the modulus!
I do not remember how the rod connector material is entered. Does it use a material in the model, or does it use input on the rod dialog? If it uses a material in the model, then create a material that has no  mass density. Then the CG will not change regardless of how larger or small you make the rods.
John Holtz, P.E.
Autodesk, Inc.
Message 7 of 11
djamal.rayane
Message 8 of 11
John_Holtz
Autodesk Support
Autodesk Support
Hi @djamal.rayane
If you zoom in on the joint between the beam elements and the cable, you will see that the cable is not connected to the beam element.
The beam elements are created at the centroid of the cross-section, and all of your sketch lines (for the beams and cables) are offset to one face of the web. Here is what it looks like in the CAD environment:
John Holtz, P.E.
Autodesk, Inc.
Message 9 of 11
djamal.rayane
thank you for your help
I fix connection, but  still have a message in solver FATAL ERROR E5001.
Message 10 of 11
John_Holtz
Autodesk Support
Autodesk Support
Hi @djamal.rayane
The problem is the cables are still not attached to the frame. The cables are attached to a sketch point that is not associated with the frame members. In other words, having the endpoints at the same coordinate in space are not sufficient to joint them all together.
This is what you should do so that the cables use the same points as the beams from the frame:
  1. Edit sketch 4.
  2. Add a point at the top of the cables.
  3. Delete the two lines representing the cables.
  4. Delete the two sketch points at the bottom of the cables. (I think there were sketch points there. Maybe not.)
  5. Repeat those steps for sketch 5.
  6. When creating each cable in Nastran, the top end is the point in the sketch, and the bottom point is the point at the end of the frame member, such as "point<7>"@Frame 16208500...". That way, the beams and cables are using the same CAD geometry to define the end point, so all of the elements are connected together.
John Holtz, P.E.
Autodesk, Inc.
Message 11 of 11
djamal.rayane
thank you it works
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
