- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Good day,
I am trying to simulate a pinned connection as part of a H-Frame bearing press below using a linear static study.
I don't think the behaviour of the assembly is correct and may be due to the way I have setup pins.
I am now using a simplified model similar to (https://knowledge.autodesk.com/support/inventor-nastran/troubleshooting/caas/sfdcarticles/sfdcarticl...) and went the route of beam elements and rigid body connectors to simulate the pin, following the tutorial as close as possible.
When I run the analysis, the beam element does not bend as expected, but rather hinges in the centre. Is this the correct behaviour or am I missing a something? Another concern I have is that the holes for the male and female clevis become misaligned. The pin does not fail in shear so I imagine the holes should stay aligned even with the exaggerated deformation shown.
The bottom face of the model is constrained in all directions and a 30000N load is placed on the top face. All surface contacts are separation. I have also tried using a surface contact between the inside faces of the clevises and the beam element to see if that fixes the alignment issue, but appear to make no difference.
Any help would be greatly appreciated.
Thank you.
Ben
