Hi @lyongoes
I made the following changes to the model, and it now runs to 47% in subcase 2 (or a load of 1.47 total). It fails at that load because that is when the press separates from the sheet, so the sheet becomes statically stable. The steps beyond 147% are not needed because nothing changes!
This is the order that I made the changes. It is hard to know if the first changes made any difference in the final solution or not.
- Removed friction from both contacts. (Friction is harder to converge, so if it does not converge with friction=0, it will not converge with friction. And it did not converge with friction = 0.)
- I noticed some penetration of the sheet and the part Solid2 (the stationary press). I changed the contact "Penetration Type" from "Symmetric Contact" to "Unsymmetric Contact". (I do not know if this really made any difference or not, but it should reduce the number of contact elements and make the analysis faster.)
- Added a mesh control to the edge of the part Solid2 where it contacts the sheet.
After getting the results, I noticed the symmetry edge of the sheet is penetrating through the the edge of the stationary part Solid2. This may be related to change #2 above. It would probably be better to keep the bottom contact with symmetry contact. Also, maybe move the sheet 0.5 mm in the +X direction so that the edge of the sheet does not match the edge of the press. (Of course, this violates the symmetry condition in theory, but if the results are better than my run, it will be worth the slight inaccuracy.)
Maybe this would be better to avoid the high stress that I was seeing along the symmetry edge of the shell. Keep the bottom contact as unsymmetric contact. Move the sheet 0.5 mm in the -X direction so that the edge of the sheet extends beyond the press by 0.5 mm.
Full pressing, but deformed shape set to 0.8 so that the shell can be seen more clearly.
I will attach my model in a few minutes.
I thought that you were going to change the sheet from solid to shell. Are you still planning on doing that? A solid with 1 element through the thickness is not very accurate. There is a Parameter that controls how many "layers" are used in the calculation of the shell. (NLAYERS. The default is 10.) That would be much more accurate than the solid. However, the contact with the shell will be tricky to setup because you need contact on both sides of the shell. I would set the normal direction of the shell to be facing the bottom stationary press, use symmetric contact for the shell to bottom press contact, and use unsymmetric contact for the shell to top moving press.
Let me know what happens next.
John
John Holtz, P.E. Global Product Support
Autodesk, Inc. If not provided, indicate the version of Inventor Nastran you are using.If the issue is related to a model, attach the model! See What files to provide when the model is needed.
