Inventor Nastran Forum
Welcome to Autodesk’sInventor Nastran Forums. Share your knowledge, ask questions, and explore popular Inventor Nastran topics.
プローブバグ報告
3 REPLIES 3
makoto_kondoU3QFH
386 Views, 3 Replies
プローブバグ報告
makoto_kondoU3QFH
Observer
Observer
異なる位置のプローブに同じ要素IDが確認されましたので報告します。
Displacementは異なるので違うIDだと思われます。
=== translate.google.com ===
We would like to report that the same element ID was confirmed in probes at different positions.
Displacement is different, so it seems to be a different ID.
プローブバグ報告
3 REPLIES 3
John_Holtz
Autodesk Support
Autodesk Support
Hi @makoto_kondoU3QFH
Welcome to the Nastran forum.
The probe is close to different corners of the same element. Is it possible that the probe is on the same element? If you move the probe slightly over the border to the neighbor element, does the element ID change?
Of course, the results are not constant over the face of the element. The probe shows the interpolated result based on the position of the mouse pointer and the value of the result in each node of the element.
John
Nastran フォーラムへようこそ。
プローブは同じ要素の異なるコーナーに近接しています。 プローブが同じ要素上にある可能性はありますか? プローブを境界をわずかに超えて隣接する要素に移動すると、要素 ID は変わりますか?
もちろん、結果は要素の面全体で一定ではありません。 プローブは、マウス ポインターの位置と要素の各ノードの結果の値に基づいて補間された結果を表示します。
ジョン
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
John
Nastran フォーラムへようこそ。
ジョン
John Holtz, P.E.
Autodesk, Inc.
makoto_kondoU3QFH
Observer
Observer
Hi, John-san,
Thank you your quick replying.
I got it.
Why don’t you show the Node ID instead of Element ID.
That’s way, ID would be identified displacement one by one.
Makoto
Hi, John-san,
I got it.
Makoto
John_Holtz
Autodesk Support
Autodesk Support
Hi Makato,
What you want to use is in the model tree, right-click on "Nodes > Query Display". Then the probe will show the result that is in the node. It does not do any interpolation as you move the mouse.
The Probe on the ribbon is used to interpolate the result between the nodes on the element. Therefore, it shows the element number that is used for the interpolation.
If you are comfortable reading English, you should look at  the PDF document attached to my forum post Suggested Reading - Tips and Tricks on the Inventor Nastran forum. Tip 51 shows the difference between the Nodes > Query Display and the ribbon Probe.
John
John Holtz, P.E.
Autodesk, Inc.
Hi Makato,
John
John Holtz, P.E.
Autodesk, Inc.
