Properly Constrained Model
travis.potier
travis.potier
One issue I am having with a current analysis is that a couple of parts in my model are appearing to be completely fixed/rigid in the analysis. The results show no displacement what-so-ever even though these components should have so displacement.
The model is of a tubular product made of round, axisymmetric components, therefore I am not running a full 3D model. I have the model set up with a cylindrical coordinate system with symmetry being applied radially. I believe the issue stems from not being able to properly constrain these components. I'm only able to apply radially symmetry to the part. Any other constraint to the part is self will limit displacement of the part in a way that will render the results to be unrealistic. In Simulation Mechanical, this was dealt with by adding "soft-springs" to nodes to provide an initial loading condition (over simplifying, but I'm hoping anyone who reads this knows what I'm referring to). What is the corresponding process for Nastran In-CAD?
John_Holtz
Autodesk Support
Autodesk Support
Hi @travis.potier
Just to be clear.
  • If you have a segment of a 3D axisymmetric model, the constraints that you are applying to the symmetry or cut faces should be in the hoop direction (theta direction, or Y in the local coordinate system). Those constraints would not be in the radial direction.
  • The model does not need constraints in the radial direction because the model is not free to move in the radial direction. It has to create stress if it moves in the radial direction.
  • It should have constraints in the axial direction to prevent motion along the axis of the model.
In-CAD has springs, somewhat similar to Sim Mech. In In-CAD, you create a connector and define the type to be spring. Prior to version X, you had to have two vertices or points in the CAD model to which you were connecting the springs. (I think "X" is version 2018 but I do not remember.) Starting with version X, you can create a "grounded" spring where you attach the spring to a vertex/point on the model, and the other end is connected to the ground. Note that the spring stiffness K1, K2, K3 ... are oriented in X, Y, Z or whatever coordinate system you choose. K1 is not in the axial direction!
So, I am not sure what is the cause of the zero displacement. Can you attach some images or the model to help clarify what you have?
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
travis.potier
John,
Thanks for the reply! I shouldn't have used the term "radial" in the context I did. I meant it to be in the "theta" direction. I will send you a screen shot of my model in a private message because of intellectual property concerns (I'd rather not have it posted on a public forum).  So, in short explanation, two of the components only have theta-symmetry constraints applied. Any further constraints applied to those parts will affect the results to negatively.
I started playing the with springs that you mentioned in your message after I made the post. Based on your comment, is it always best to click "advanced options" and insert values for all 6 K's instead of just inserting a single K value? I'm trying to remember the exact procedure I used with Simulation Mechanical. If I remember correctly, you had to have two springs for each direction (one in the "positive" direction, and one in the "negative" direction), so for a 3-D model it required 6 springs and for a 2-D axisymmetric model 4 springs were required (my memory could be failing me). With the grounded spring, would one spring with K values for all directions replace them all?
Thanks for your help!
Travis
John_Holtz
Autodesk Support
Autodesk Support
Hi Travis,
For the orientation of your model, you need a spring with stiffness in the Y direction on any of the parts that do not have a Y constraint (in the axial direction). I think that entering a single stiffness assigns the stiffness in all 6 directions which should be acceptable for your situation. (A small stiffness in all directions is not going to affect the solution other than providing stability.)
Are you getting warnings when you run the analysis, such as it was not converging? That would be one reason that the load would not be transferred to the other parts.
The other possibility would be if contact were missing or not detected. I suggest setting the "Penetration Type" on the contact setup to "Symmetric". (It may be set to that already.) Another test would be to change the contact type to bonded just to check if the contact is detected.
John Holtz, P.E.
Autodesk, Inc.
travis.potier
John,
Thanks for the input. The only error messages I'm getting are G3051, G3012, G3014, and G3015; nothing regarding convergence issues. I'll rerun the model with the springs as you indicated as well as changing the contact to penetration type and see what happens.
Travis
travis.potier
John,
The penetration type on all contacts are/were already set to symmetric. I've applied a spring to all components without a "Y" constraint. Now I'm getting fatal error E5001 "non-positive definite detected at grid....". I've tried to do some searching made some modifications, but am still getting the same fatal error. Is there a special procedure required to apply springs in this manner?
travis.potier
John,
I was able to get the model to run by applying bonded contact types to all of my contact surfaces. Per our conversation, I'm certain the error message I got with the springs installed is due to not constraining the "free end" of the springs. Thanks for your help.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
